11-25-2017, 02:23 AM | #2 |
237
Rep 312
Yeah, burger tuning's JB+ and JB4 are both compatible with B48
http://www.burgertuning.com/B48_B58_...all_tuner.html http://www.burgertuning.com/B58_JB4_...nce_tuner.html
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile |
11-25-2017, 02:50 AM | #3 | |
155
Rep 131
11-25-2017, 03:10 AM | #4 |
237
Rep 312
I'm sure it is, Ask him directly at terry@burgertuning.com
11-26-2017, 02:32 AM | #5 |
2018 530i
25
Rep 67
30whp seems like the max B48 can take with ecu chip tuning.
RAPID chip also released their product, and quite a few members are getting 30whp gain as well. which is not bad at all for under $1000 investment. Although i was hoping it could hit 300hp (not whp) with the chip.. |
11-26-2017, 01:31 PM | #6 | |
155
Rep 131
11-26-2017, 06:32 PM | #7 | |
1112
Rep 2,069
Or to put another way, if you can't notice, you don't need the extra power. |
11-28-2017, 08:21 AM | #8 | |
2018 530i
25
Rep 67
530i is putting down anywhere from 220 ~ 230 at the wheels. Chip will get you somewhere around 250~260. I've seen 265 on premium gas mapping today. It doesn't feel much down low, but difference truly shows on the highway or when the RPM goes above 3000rpm. |
12-16-2017, 10:34 AM | #9 |
2018 530i
25
Rep 67
Just an update, people are hitting 270~275whp with 700 dollar chip tuning without other modifications. Simple bolt-on.
That puts us into a slightly slower 540i stock range. Just FYI. |
01-01-2018, 10:24 AM | #10 |
39
Rep 88
Does the b48 from the 530e and the 530i net the same end hp?
2023 BMW iX50; 2023 BMW i435; 2018 BMW X5 35ixdrive - Jb4; 2018 530e M Sport Alpine White - AC Schnitzer; 2017 F80 ZCP Sakhir Orange - VF Engineering Hex (Sold); 2016 F82 ZCP Black Sapphire - VF Engineering Hex (sold); 2016 BMW i3 - "Tuned" - Coded (Sold)
02-18-2018, 02:44 PM | #11 |
2018 530e, E30 325ix Touring
Rep 3
In the EU we also have a 520i, as far as I can see , the 520i , 530e and the 530i has the same engine. But what is the difference ? just tuned down for the 520i and 530e ?
Or does the 530i have som different parts to get more power? |
FlyingWombat243.50 |
02-21-2018, 10:11 AM | #12 |
23
Rep 112
I have my 2018 530i now for 4 months and have have tried 2 different tunes. First I had the JB+. It was set at 4 pounds of extra boost and took about 30 seconds to install. I liked it. You can definitely feel the difference.
But then I had the chance to pick up the dinan sport tune. I am liking this tune a lot more than the JB+. It took 5 minutes to install because it plugs into an extra sensor and I zip tied the wires to hide them. It has Bluetooth so you can switch between different boost pressure settings and even has a built in boost gauge in the app. Although it supposedly only increases boost by 4 pounds, it feels substantially stronger and smoother than the JB+. Luckily I got a 430 GC for the wife so I put the JB+ in her car. When I get bored, I'll try the JB4 and possibly the Active Autowerke tunes. So far I'm very happy with the Dinan tune. |
Tyresian69.00 |
02-21-2018, 01:55 PM | #13 |
3086
Rep 4,210
02-22-2018, 07:41 PM | #14 |
Joint Chiefs of Staff
24140
Rep 190,687
Although BMS website does not have the 530 under list of compatible cars with the Jb+ and Jb4 im sure it is compatible.
I sent an email to Terry to confirm
Reynolds2303.00 |
02-22-2018, 10:16 PM | #15 |
24140
Rep 190,687
Confirmed by Terry, JB+ and Jb4 compatible with the 530
03-01-2018, 12:14 PM | #16 |
Rep 147
FWIW, for those with the 530e, I've received confirmation from Terry that both the JB+ and JB4 B48 tunes will work on the 530e. I'm excited to try these out.
I contacted Dinan and they said their tunes are not compatible with the 530e, so there's that. |
03-03-2018, 04:58 PM | #17 |
325
Rep 5,370
Why would one work and not the other...seems fishy or one is right and other wrong
03-05-2018, 04:19 PM | #18 | |
Rep 147
I bought a JB+ to test it out. Will post my impressions. I know there's another forum member who's been running the JB+ on his 530e for the past 3-4 months without issue. |
06-20-2018, 10:28 PM | #20 |
12
Rep 28
Post JB+ Experience
Ok guys - I just installed the JB+ on my 2018 530e this evening. I was a bit nervous but I saw that this will go only in one of the map connectors and was also worried if I fitted it losely but it came out to be a snug fit. Also, I don't think the engine would have fired if I had connected it losely so all is good. I also maxed out the psi level all the way clockwise to the right (5 o-clock).
So then I took her for a spin up and down the hills, about 10-12 Miles round trip, and quite frankly, didn't notice much of a difference. I had gauged with the sport displays before the JB+ and it had tapped out at 240/300 and I had similar results after the JB+, maybe around 250/310. I drive efficiently most of the time so flooring the gas l is not what I do usually but I did most often in my "test drive" post JB+ installation, but it didn't go past 245-250ish. Is there a break in and learning period for the JB+? Am I going to feel the difference on the freeway when I pass other cars? Tell me more ... |
06-26-2018, 12:09 AM | #21 | |
57
Rep 164
06-26-2018, 12:43 AM | #22 | ||
12
Rep 28
