Endlinks for Air Setups?
11-23-2017, 09:49 AM | #1 |
44
Rep 165
What kind of front sway bar endlinks are the folks with airsuspension running? I bagged my 335, but first moment pulling out of garage, both sides oem end links snapped in half. I've rechecked my installation and everything seems fine, I even ensured the mounting point for the endlink onto the front strut was identical in location to the oem strut. Figured the height difference is what compromised the endlink. I've been looking at adjustable Hotchkis endlinks, if anyone has any experience on this I would appreciate it!
@balxoscar
@1visionperformance |
11-25-2017, 03:12 PM | #3 |
44
Rep 165
Airlift front struts. The rear bags are sleeve BagRiders, but there has been no issue whatsoever with the rear. That's interesting, I am not sure as to why my end links snapped. By any chance do you have pictures of the front struts mounted?
@balxoscar
11-25-2017, 07:45 PM | #4 |
Photographer
413
Rep 2,643
The tab on the strut goes in the split of the hub, that's how you know it's located correctly.
What pressure do you have to run on the rears? Can't imagine having a sleeve on the back of these! |
11-26-2017, 01:30 AM | #5 | |
44
Rep 165
I have to inflate them to roughly around 100 psi for the sleeve to fill up before the rear goes up at all. But after that, its just like a normal bag, I can drop to 70-ish psi for extreme flush fit, but I'm usually around 105-115 for highway/city driving (San Jose has terrible roads)
@balxoscar
11-26-2017, 11:57 AM | #6 |
Photographer
413
Rep 2,643
You want to be careful running a sleeve bag over 100psi as I've heard a lot of people have issues with them at high pressure.
Double bellow I run at 70-80 PSI, 95-100 is all the way up. |
11-26-2017, 11:06 PM | #7 |
44
Rep 165
What kind of issues arise with sleeve bags? I haven't experienced anything unusual with the pressure I run, on these 115-125 psi is as high as the car will go. 70-80 is incredibly low for to daily drive. Do you have Airlift bags and management?
@balxoscar
11-27-2017, 01:10 PM | #8 |
Photographer
413
Rep 2,643
Sleeve's don't seem to last that long when running high pressures like that, seals blowing etc, they're only really designed for small light cars.
On my Airlift Double Bellow rear bags 80 psi is tyre level with arch. From what I've read sleeves aren't that great ride quality wise either. I have the complete Airlift kit that they sell, including different lower control and toe arm. |
01-11-2018, 12:39 AM | #9 | |
44
Rep 165
Attached I'll put a picture of my front passenger side strut, the bracket for the endlink is hardly visible/behind the strut. the picture was taken perpendicular to the rotor and wheel well. Does this look correctly positioned? Or do I need to give it another rotation/adjustment/switch left and right struts? I have bought new adjustable Hotchkis endlinks. I just want to be sure I have the struts correctly positioned before installing these in order to avoid similar issues
@balxoscar
03-01-2018, 10:48 AM | #11 | |
44
Rep 165
Other than that, haven't had any issues with them as of now. But in the future I will be looking for shorter links so I can install and properly adjust to remove preload on sway bar.
@balxoscar
03-02-2018, 05:29 PM | #13 |
44
Rep 165
What is ARB? Also, ideally I would want to have longer ones, but the Hotchkis I have now barely fit, even at their shortest adjustment
@balxoscar
