TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Starter question
      11-20-2017, 08:47 AM   #1
Mtl128_25
26
Drives: 328i 2008
Starter question
Quick question: my car is sometimes randomly hesitant to start and i suspect the starter since i have already changed in the last year the coils, sparks plugs, battery etc..
My question is: can the dealer diagnose that a starter is starting to fail? Or it will simply be one day the car wont start?
Thanks for your help.
      11-20-2017, 09:23 AM   #2
xichrisixBMW
xichrisixBMW's Avatar
16
Drives: 2016 BMW M328I & 2013 BMW 328i
2016 328xi M  [0.00]
Yes it is a process of elimination; the ground cable ( common issue-rot out ) then starter itself. Dont wait go to a good independent BMW shop not the dealer for a 2008 car...you'll end up stranded on a cold night somewhere
      11-20-2017, 10:20 AM   #3
UK_Nomad
44
Drives: 2007 E93 325i Cabriolet
My car refused to crank about 2 weeks ago. I only got the car 3 months ago so I don't know what a healthy starter is like - mine was working ok until 1 day it just refused to start.
A new starter motor fixed my problem
I'd suggest you undo and clean/refit all the battery and earth cables while it's still working.
I found it useful to trace the starter circuit in the engine compartment, then it's easy to tell if the starter is getting 12 volt "trigger" when you press the starter button.
If you have good power, earth, and starter trigger voltage and still have problems - swapping the starter would be my next step.
Good luck, let us know how you get on
Ex BMW owner (2007 E93 325i, E36 325i & 328i from the 90's)
      11-22-2017, 03:00 AM   #4
Mtl128_25
26
Drives: 328i 2008
I have to bring it to dealer since the the party extended warranty mentions this. The warranty expires in 2020.
So the dealer would be able to diagnose it even if the longer cranks are longer only in random occasions?
      11-22-2017, 07:16 AM   #5
JFolt
14
Drives: 2011 335i Sedan
My 2011 e90 has been doing the same thing, every once in a while the starter sounds like it's not going to make it... One of the last times I was at the dealer they told me there was some ghost code that suggests the starter is on its way out.... So I think that the dealer can diagnose it in some cases.
