Valeo or Denso Heater Core..??
11-13-2017, 06:42 AM | #1 |
Maximus Decimus Meridius
1130
Rep 4,584
Is there any possible way to identify which heater core is currently in there before ripping the entire dash apart..?? I'd like to get this all done on the same day as my car is my daily driver, but if I have to take apart the dash to see what the brand is, and that'd be a huge delay..
I've called and searched around and everyone asks me which of the two is it, but idk where to find that info out as it doesn't seem VIN specific.. Thanks..
F30 335i Melbourne Red Metallic M-Sport Package |
11-13-2017, 08:47 AM | #2 |
267
Rep 1,203
Remove your radio, their will be a sticker on the heater housing..Im 99% I've never seen a Denso heater box in any e9x (they are all valeo) and I've done plenty of evaporator . On a side note you don't have to remove the dash entirely to do just a heater core.. U can sneak it out
11-13-2017, 09:09 AM | #3 | |
1130
Rep 4,584
11-13-2017, 09:21 AM | #4 | |
1130
Rep 4,584
11-13-2017, 09:35 AM | #5 |
267
Rep 1,203
You can remove the heater core 3 ways IMO
-Remove entire dash, support and blower box (Most labor, and you have to EVAC A/C) -Remove dash covering leaving box in place and sneak out (My preferred choice) -Remove steering column and sneak out |
11-13-2017, 09:41 AM | #6 | |
1130
Rep 4,584
From the other thread I made about the leaking heater core which I'll link below, you can see in one of the images the line i'm referring to. http://www.e90post.com/forums/showthread.php?t=1438967 I put an arrow pointing to the hard line I'm talking about..
F30 335i Melbourne Red Metallic M-Sport Package Last edited by BeastMode335i; 11-13-2017 at 09:47 AM.. |
11-13-2017, 09:53 AM | #7 |
267
Rep 1,203
I believe the hose your referring to is an cooling vent line for the CCC/CIC system not an actual A/C hard one..It should be just press fitted on. The hard AC lines are in in the molded plastic above the heater core lines..U can somewhat see in the picture that its routed around the heater box
BeastMode335i1130.00 |
11-13-2017, 10:34 AM | #8 | |
1130
Rep 4,584
11-13-2017, 10:45 AM | #9 |
267
Rep 1,203
Yeapp, its just a rubber hose with nothing more than air flowing threw it
11-13-2017, 10:59 AM | #10 | |
1130
Rep 4,584
I did read on the E46 forum, some got theirs out without removing the dash as well, but it seems like they have a bit of a different layout than we do back there.. Figures.. I do appreciate your help btw, seems like you're the only person on here who knows about this specific job lol..
11-13-2017, 11:17 AM | #11 | |
267
Rep 1,203
11-13-2017, 11:21 AM | #12 |
1130
Rep 4,584
Haha yeah I actually didn't intend on looking at any other platforms for assistance, but when I typed "heater core replacement e92" in Google, I found like 1 result, so I started outsourcing out of disparity haha..!
11-13-2017, 07:08 PM | #13 |
1130
Rep 4,584
with the steering column and sneak out method, that can be done with the dash still in place..??
11-14-2017, 09:21 AM | #14 |
267
Rep 1,203
Assuming you remove the steering column completely and willing to break the foam to the right of the column. U can sneak it out..
11-14-2017, 09:23 AM | #15 |
1130
Rep 4,584
Hmm, sounds like removing the dash may be a bit lengthier of a process, but helps to avoid breaking stuff lol.. I may try your "preferred method" with leaving the evaporator box in place and sneaking out the core.. In this method, is it simply just the dash being removed, and column being dropped that helps sneak it out..??
11-14-2017, 01:30 PM | #16 |
267
Rep 1,203
If you look at the picture of the heater core being removed there is a block of foam to the left. Well their is a block of foam to the right as well not picture..By design it wont come out with the dash in place unless u break it of its screw..Is it super important, probably not. So that's your call on removing it. But if you do decide to remove the dash cover and sneak it out, then lowering the steering column is all that's needed to sneak it out. I can have the dash off an e90 in an hour so its not a big deal for me, I dont know your comfort level to say one way or another. Its not complicated but you can easily forget things or get wire layout mixed up
BeastMode335i1130.00 Timujin352.50 |
11-14-2017, 01:44 PM | #17 | |
1130
Rep 4,584
But yeah I understand what you're saying.. I thought about slowly taking the dash apart over the next 2-3 days so once Saturday morning comes (and my parts arrive) I can just knock out the basics and be done with it.. I'm attaching a picture that pertains to this next question.. In order to sneak the core out, do I have to remove those two vent motors, or can I just remove those two screws I circled in red and remove it that way..? Thanks again!
11-14-2017, 02:09 PM | #18 |
1130
Rep 4,584
Hopefully it's as easy as this guy makes it look to get good enough access to sneak it out haha..
11-14-2017, 05:25 PM | #19 |
267
Rep 1,203
If memory serves me, you gotta remove the the servo motor, and then remove the heater core access door and it should come out.
11-14-2017, 05:27 PM | #20 |
1130
Rep 4,584
Alright sounds good.. I popped out the radio to see if it was a valeo, it was, so luckily I ordered the right kit lol..[IMG]undefined[/IMG]
12-08-2020, 05:45 PM | #22 |
Rep 3
Which heater core?
I removed radio to see which HVAC sticker was there and it was a Valeo
(Actually Valeo 98285oh). However when I removed driver side access panel, I saw the actual heater core and it says its a Denso on the actual core. Its a 2006 e91. Based on that, which heater core should I order? |
