11-12-2017, 05:12 PM | #1 |
Rep 54
Drives: F22 M240i
M240i iDrive complete shutdown!!?
Hi Guys,
I pumped through a few areas on here looking for any similar issues. Starting two days ago, I experienced several times my iDrive system screen flickering, followed by the speakers crackling and popping, resulting in the iDrive system completely shutting down including dash lights and info screen. It seems to do it significantly more while my iphone 6s is paired via either USB or Bluetooth and I'm streaming music. It will restart straight away and revert back to the same Classical Radio station I never listen to. Does she need a software update? or is she giving up? I have my first 15,000km service due in two weeks. Car is going in for some warranty work as well, moisture in the tail lights, dash trims around around climate and radio buttons coming loose and now this. Any advice? Anyone else experience this? Cheers |
11-12-2017, 11:53 PM | #2 |
116
Rep 509
Drives: 2016 M235i RWD 6MT
Could be your iPhone causing the issue but that's just a preliminary guess.
Check this thread: http://www.2addicts.com/forums/showthread.php?t=1431797 as someone was experiencing iDrive shut downs when syncing with their iPhone 8. Their issue was resolved by turning off contact sync? It could be somewhere else in your phone that's corrupt causing it to crash. Easiest thing to do is to connect a phone that has all contents reset to factory default so that it doesn't have anything and see if it continues? Good luck.
2016 M235i RWD 6MT - Current! as of July 28/16
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
WillOs7.00 |
11-13-2017, 12:01 AM | #3 | |
Rep 54
Drives: F22 M240i
"Take me to - 'the most outrageously priced shoe store'" did not work hahaha |
11-16-2017, 03:30 AM | #4 |
Rep 54
Drives: F22 M240i
Updated phone, now bluetooth pairs, but Navigation, Voice prompt, majority of the I-drive interface gone.....? Is there a way I can flash the software onboard? or Dealer only?
11-16-2017, 04:42 AM | #5 |
195
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
You can do it yourself but you need;
-ISTA+ with the latest I-level (which is currently 4.08.13) -OBDII cable with your choice of connection to the computer (Ethernet seems like the fastest and most stable connection method) -A battery charger (preferably BMW approved) After that it’s kinda easy, so I guess you can do it yourself however, if you are going to take your car in I would wait and just tell the dealer about the problem and not offer the possible solution as they might mark it as customer requested update and charge you for it. Also as far as I can remember, the BMW’s AIR system, showed there is a PuMA measure for this issue and it recommends for the cars software to be updated. |
WillOs7.00 |
11-16-2017, 05:23 PM | #6 | |
Rep 54
Drives: F22 M240i
Still love the thing though, puts the biggest smile on my face daily! Thanks for your help! |
