11-11-2017, 05:12 PM | #1 |
40
Rep 95
Bavsound
I was reading the latest issue of The Absolute Sound, an audio magazine that frequently reviews components and speakers that cost as much as BMWs, when I came upon a one-page review of the stage one Bavsound speakers. The author owns a BMW three series with the base sound system, hated the sound, and swapped out the speakers except for the subs with Bavsound stage one speakers. He loved the difference the new speakers made. He described the purchase as arguably the best $600 he had ever spent on a stereo system.
I went with the stage one speakers, the new version of the Ghost subs, and the Bimmertech amp. It has made a night-and-day difference. The so-called premium HK system in my 240i somehow managed being muddy and shrill at the same time. The Bavsound system has very good resolution, and the instrument timbres sound correct, as do voices. It sounds so decent that I have resisted the strong temptation of playing with the DSP, just to make sure that I do not screw it up. |
12-04-2017, 10:20 AM | #2 |
15
Rep 55
I put the Stage 1 speakers in my H-K equipped M240i last week, and am very happy with the improvement. Did you add the amp after the Stage 1 speakers and subs or at the same time? If after, any comments on the improvement difference between doing just the speakers vs. the the amp? I'm considering the Bimmertech amp but really not sure if the additional improvement is worth the cost. I'm less likely to do the subs, but I might.
12-04-2017, 01:27 PM | #4 |
40
Rep 95
Mecodoug,
I originally ordered the stage one and the amp; I would probably have ordered the subs as well, but they were not available (Bavsound was switching to the V.2 subs). As it happened, Bavsound sent the installer the wrong brackets for the speakers, and so I had the amp put in. Then in a week or two the correct speakers arrived, and I had them put in. When the v.2 subs became available, I ordered a pair and installed them myself. The amp by itself made a considerable improvement to the HK speakers, even though it was tuned for the Bavsound speakers. The sound had better resolution overall, and the treble was not so shrill. I would extrapolate from that and guess that it would also result in a considerable improvement to the Bavsound speakers. The stage one speakers also made a considerable improvement. Yet better resolution, and normal treble. The bass, however, was still muddy, and there seemed to be a hole in there. That is why I tried the new subs when they came out. The made a huge improvement to the bass. It was not just that the bass was louder--which it was--but that it was no longer muddy. I thought that each of these improvements was well worth the cost, and the system did not sound really good to my ears until they were all in place. If you want to hear if the improvements are worth it to you, you could always install the amp and the subs and hear what they sound like. Bavsound will let you return them within some period of time. Good luck. |
12-05-2017, 11:39 AM | #5 |
Rep 23
My Bavsound stage 1 speakers for the hi-fi system gets here tomorrow, I am very excited for it. I also ordered the insulation and tool kit to do the installation myself. Hopefully I don't break any clips.
I'm wondering if that will be enough for me. I'm pretty disappointed that the car is not recognizing music files over USB through my galaxy S8, and the lack of auxiliary input. |
12-07-2017, 11:03 PM | #7 |
87
Rep 220
12-10-2017, 12:58 PM | #8 | |
4516
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
12-16-2017, 07:45 AM | #9 |
54
Rep 176
Have been following this thread with interest and was wondering if anyone with a convertible has changed out the speakers and how happy they are with the results. A car is a poor sound environment but a convertible car even worse. Hate to spend a bunch of money and not get some significant improvements.
thanks |
12-16-2017, 09:31 AM | #10 |
15
Rep 55
I can't speak to the convertible, but stage 1 is definitely a major improvement over the coupe H-K speakers. After listening for a couple of weeks I've decided to do the subs as well and they are on order.
Still undecided about the amp - I'm hoping the subs will be enough. |
12-16-2017, 11:07 AM | #11 | |
4516
Rep 8,942
Amp is more difficult swap due to access in trunk but speakers and ghost subs were easy and definitely worth the $.
2022 Macan S
12-23-2017, 02:35 PM | #12 |
15
Rep 55
Completed the subs yesterday - will give them a week or 2 to break in before passing judgement. Initially the sound is less muddy but not louder.
I wonder if there is anyone in central MA/CT/Western MA who went the Dr. Strangelove route who would like to compare? |
12-23-2017, 04:15 PM | #13 | |
228
Rep 301
01-03-2018, 07:25 AM | #14 |
15
Rep 55
Now that my Bavsound components and the subs are fully broken in, I can report that the improvement is substantial. I had noticed that using bluetooth as a source, the volume was so low that I had to crank it to 90% or so. I knew that I should hard-wire my source for better quality anyway, but my iPhone 8 has a wireless charging cradle vent mount, and I did not want wires. So I took an old 32 GB iPod touch that was lying around and installed it via USB in the armrest. With USB as a source, the volume is much higher - I only need about 60% vs. 90% with the Bluetooth source. And of course much better quality with uncompressed or very high bit rate compression files.
At this point I believe the H-K amp is sufficient and I have no plans to upgrade it. Though more expensive than the setup from the Dr. Stranglove thread, I can highly recommend going with the full Bavsound speaker upgrades and a quality USB source. |
01-03-2018, 07:30 AM | #15 | |
4516
Rep 8,942
2022 Macan S
01-07-2018, 12:45 PM | #16 |
36
Rep 129
01-07-2018, 02:42 PM | #17 |
4516
Rep 8,942
Yes but the DAC on the car leaves something to be desired. Any lossless though is better than not.
2022 Macan S
35mmSummicron35.50 mecodoug15.00 |
