2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum weird deep resonance
      11-10-2017, 04:08 PM   #1
Ron Jeffries
Old Member. Old in general, actually.
388
Drives: 2018 M240i xDrive convertible
over rough pavement, new snow tires, new MP exhaust. car has deep resonance from left front, sounds low down inside or below car. seems that the stereo can produce it sometimes as well. seems to be road speed dependent, not engine speed.
very strange and quite irritating.
      11-10-2017, 04:30 PM   #2
Dylan86
Dylan86's Avatar
1330
Drives: F15d msport, F22 m235i
Could it be the "Active Sound"? It's the phony engine sounds that come through the stereo..
      11-10-2017, 06:01 PM   #3
jmwilson125
341
Drives: 2016 M235i
Maybe it's just the tires and it seems to be coming from that area? Any wheel change as well? Could it be rubbing?
      11-10-2017, 07:14 PM   #4
Ron Jeffries
388
ASD is off, plus this is much louder than ASD.
It’s a single tone, doesn’t rise or fall with speed or engine revs. sometimes there, when car speed over slightly rough pavement is right. something’s picking up and amplifying tire/wheel vibration or the like ...
except it seems some notes from the radio will do it as well, but only sometimes. couldn’t get that to happen when stopped, so not certain on the radio thing.
      11-10-2017, 08:04 PM   #5
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
I'm gonna say it's the snow tires. I have snow tires on my mazda3 and they ride and sound like absolute crap on anything other than snow.
Poochie9104.50
      11-10-2017, 09:18 PM   #6
wdc330i
223
Drives: '22 M440xi GC
Stop worrying about stuff and enjoy driving your new car? I'd also suggest stop modding it, until you settle into every day life with it. Let it rest for 6 months or so, then figure out if you need to change anything more.
'22 M440xi GC (BSM/Tacora) Previous: 2017 M240i Convertible; 2016 X5 50i; 2017 Boxster 718s; 2012 328iT Sport; 2009 X5 3.0; 2006 M3C; 2006 530xiT; 2003 325xiT; 2002 330i Sport; 2001 Z3 2.5; 2001 330i.
CAMOETO140.00
      11-10-2017, 09:21 PM   #7
Rony316
19
Drives: M235i XDrive Convertible
Remove all variables first and re-examine. Empty cup holders, center console, glovebox, trunk. Everything. Had a weird resonance that was caused by a can in the door cup holder. Drove me crazy.
2016 F23 AW M235xi
      11-11-2017, 05:47 AM   #8
Ron Jeffries
388
it’s not the snows: i can hear them, too, and their tone is higher, more of a ringing, and changes with road speed. the resonance does not. plus, with window open, i hear them, but not the resonance, outside.
agreed on eliminating things by emptying the car, and i’ll do that. there’s not much in it, since it’s new, but there is stuff.
it was not making the noise the first few days on the snows, nor first few days with MPE. Just started yesterday. It’s like a panel is loose, or possibly something underneath bumping, but it’s a low dull drumming kind of sound, not a sharp rattle.
As for just enjoy the car, sure, but this is loud enough and resonant enough that even with radio loud, you hear it. on a trip it’d drive you crazy.
natch, i’ll take it to dealer if emptying the car doesn’t fix it.
      11-12-2017, 07:01 PM   #9
Ron Jeffries
388
Is the exhaust pipe from engine to rear on the left side of a left hand drive M240i? I just had the MPE put on before the noise started. I wonder if in hooking it up they may have allowed the exhaust to bump against the car somewhere along the way.
Guess not according to the pics I can find ... still, that's the most recent change before this weird drumming noise.
      11-13-2017, 02:12 PM   #10
Maynard
3848
Drives: 228iX & M2C
Looks like you are thinking to bring it to the dealership, which would be my suggestion. Might be worth considering an alignment check, as that can give you a sort of low grinding noise (at least that was what tipped me off that I was out of spec). Also might try pulling the stereo fuse to see if that stops it, as a way to r/o the ASD and related stereo acoustics.
      11-13-2017, 03:24 PM   #11
Ron Jeffries
388
Yeah gonna take it in Thursday. I'm almost convinced it could just be tire noise but its deeper, more bumpy, and less ping than usual tires. When I started it this morning I def heard what sounded like exhaust rattle, during that rough period right after a cold start. Could have just been the vans but deeper in tone than I expect.
I figure they might find something, might blow me off. If it's the tires I wonder if a different brand of snows from the Contis might be quieter.
      11-14-2017, 07:16 AM   #12
Maynard
3848
Drives: 228iX & M2C
The tire noise I get tends to be very surface-dependent, so it will on-off as you hit patches of different pavement and vary with speed. Mis-alignment would tend to be more steady like you describe, may vary with turning. I suspect that my car was poorly aligned from delivery, since the noise I questioned had been there all the time, but went away once they corrected alignment. That start-up rattle may be a common feature of the sport exhaust valve - you can search for a thread here that does into a lot of detail about what is normal vs. stuck valve (but wouldn't expect it to give a deep rumble, seems more like it makes a rattle).
      11-14-2017, 09:54 AM   #13
Ron Jeffries
388
there is allegedly no valve on the 2018 m240i. i’ll try to remember to have them think about alignment. on a new car, what’s up with german precision these days?
      11-15-2017, 07:22 PM   #14
Ron Jeffries
388
I'm starting to think that the noise might actually be mostly the tires. Are the Conti WinterContacts particularly loud? I'm sure I'm getting some resonance, sometimes, from a body panel or the exhaust but it could be the tires starting things. I may have to find some grass to drive on as a test ...
      11-20-2017, 04:13 PM   #15
Ron Jeffries
388
Took car to dealer today and shop foreman drove it. He seems pretty sure all the noise is the ContiWinterContact tires. I'm not convinced but not willing to give them the car for a day to search for a sound he can't even hear.
      11-24-2017, 09:02 AM   #16
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
What????? There's something louder than ASD?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
2addicts
