Help! Where is this oil coming from? N55 with oil cooler
11-09-2017, 04:18 PM | #1 |
38
Rep 137
My belt started squeaking, and taking a look around there is a little bit of oil on the serpentine belt, on my charge pipe, and some near the fan and down below onto the under body plastic paneling.
I'm thinking it's my oil filter housing gasket but then I saw more oil on the engine, please see the attached photos. What's causing the oil to leak in this location on the engine? I have a 2011 335i xDrive, with the N55 engine and with an oil cooler. If it's the OFHG, is that difficult on an xDrive with oil cooler? The 3rd bolt is under the intake manifold and appears to have no access, unlike some other photos I've seen. If the intake manifold is loosened, does the intake manifold need a new gasket after loosening the bolts? I'm not sure if it's the OFHG, but I would appreciate any insights you all can offer. |
11-09-2017, 06:34 PM | #3 |
Rep 10
You’ll have to loosen up the bolts on the valve cover to get to that corner bolt. No need to replace the valve cover gasket if you torque everything back down properly and in sequence
11-09-2017, 06:42 PM | #4 | |
319
Rep 1,023
Also, since you have the oil cooler there are 2 gaskets you should replace on the oil filter housing - the OFHG and the Oil Filter Control Housing Gasket (OFCHG). You should take a look around the valve cover, though - they start leaking at around the same mileage as the OFHG, generally.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
11-09-2017, 07:06 PM | #6 | ||
38
Rep 137
Lastly, what are the part numbers for all these gaskets I need. Thank you everyone |
11-09-2017, 08:01 PM | #8 |
190
Rep 937
11-09-2017, 09:23 PM | #9 |
38
Rep 137
I found the following part numbers:
11428637821 Oil Filter Housing Gasket 11428637820 Engine Oil Cooler Gasket Is this all I need and does anyone know who makes these for BMW, is it Mann? Or should I buy original BMW. |
11-10-2017, 02:01 PM | #11 |
190
Rep 937
11-10-2017, 07:54 PM | #12 |
38
Rep 137
I purchased both gaskets today direct from BMW. I'm going to tackle this in the morning. If I need to loosen the intake manifold, what is the torque and sequence when I put everything back?
11-12-2017, 06:50 PM | #13 |
38
Rep 137
I replaced the OFHG and the oil cooler gasket, both were deteriorating so I'm glad I did both.
I did need to loosen and move the intake manifold. For future reference if you have an N55, you have to loosen and move the intake manifold as there is absolutely no room for the 3rd bolt. With N54 engines this may not be necessary. Does anyone know the sequence and torque for the 7 manifold bolts? Same question for the housing screws❔ Lastly, there is a tube attached on the right side of the filter housing that carries coolant. Some coolant leaked out, does that mean there is air in the system now and I need to bleed the coolant line of any air? If so, what's the procedure for bleeding coolant line of air? ❔❓ Thank you! Last edited by MyCar; 11-12-2017 at 07:02 PM.. |
robthewrench266.00 |
11-12-2017, 08:11 PM | #14 |
319
Rep 1,023
I can't recall the torque specs off the top of my head, but the sequence isn't important. Snug them all up before torquing any, though. There should be a DIY on the forum somewhere with the torque specs, else maybe I can look it up in the Bentley manual later.
For the coolant bleeding procedure: -Hook up a battery charger. Proceed at risk if without this. -Turn the car to "on" (do not start the engine) -Turn the HVAC to the hottest setting, and the minimum fan speed -Hold the accelerator pedal down for ~10 seconds, until you hear the water pump start running -Let the car do its thing for ~10 minutes, and add coolant as necessary
11-12-2017, 10:34 PM | #15 | |
38
Rep 137
So that's it, the system will bleed of any air itself just by doing the above? I don't have to open any valve or anything to let the air escape? What happens if I don't use a battery charger and battery dies? I have an old school battery charger, just hook it up to the battery while the battery is hooked up to the car? |
