Oil Change indicator gone crazy
11-02-2017, 01:42 PM | #1 |
Rep 25
2006 - e90 - 325xi.
yesterday the oil change indicator lit up. So ran the diagnostics and said +1qt. Its indicator was on the min. I added 1qt of 5w-30. Now the indicator is at max. Just adding 1qt showed this much variation. Is it correct or something wrong ? |
11-02-2017, 02:05 PM | #2 |
145
Rep 506
In most cases, the difference between the min and max lines on the dip stick or electronic indicator is about a quart of oil. I think you're good!
2010 335I Xdrive
You're not really driving if you don't have 3 pedals. |
11-02-2017, 02:05 PM | #3 |
3764
Rep 2,738
Sounds correct. That indicator is only for the last quart, it doesn’t measure the whole oil pan capacity. So when it shows at Min level it means you are 1 quart low
11-02-2017, 02:26 PM | #4 |
971
Rep 3,863
Drives: 330i, 135i
11-02-2017, 02:28 PM | #5 |
Is it the shoes!?
3884
Rep 5,112
The engine oil level indicator measures in 1/4 quarts. The bottom of the indicator means you are 1 quart low. Adding one quart brings it back to max.
11-02-2017, 03:28 PM | #7 |
1706
Rep 14,829
Has anyone observed an overfill condition indicated by the electronic dipstick? I've never seen mine anywhere except max, and I don't want to underfill and run the motor to test it....just curious. I always do 6.5 when I change it, not 6.8...
11-03-2017, 02:11 PM | #8 |
126
Rep 482
If you overfill it will show. And that is bad. Someone posted a pic of the idrive display with the overfill condition and it looks nasty. Not sure on which forum now - it was a while ago.
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
11-03-2017, 03:08 PM | #9 |
1861
Rep 2,554
I?m confused. It said add 1 quart and you did and now it?s fine. Whats the problem?
