10-24-2017, 09:39 PM | #1 |
25
Rep 120
Drives: 2018 BMW M240i
automatic map updates for MY2018
I thought the newer iDrive systems supported automatic map updates. Did they remove this feature for MY2018? My car shows that it's still on 2017-1.
11-08-2017, 09:31 PM | #2 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
The crap part is if you are back and forth between two regions, you get screwed.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
11-10-2017, 07:38 AM | #3 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
You have to "manually" update the base map info every year or two, but you get free regional updates supposedly 4 times a year via satellite. I recently updated the base map on my 2016 228i, and went through a private vendor rather than BMW. Cost $70 and about an hour's time all told, including downloading the update, unpacking it onto a USB drive, and then plugging the USB into the port in the center armrest and letting the car upload it.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
11-12-2017, 02:20 AM | #4 |
25
Rep 120
11-14-2017, 05:28 PM | #5 | |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
iDrive Map Updates
Thanks for the info! |
11-15-2017, 07:13 AM | #6 | |
1837
Rep 6,990
Redbeemer88.00 |
11-16-2017, 04:21 PM | #7 | |
Ne Plus Ultra
88
Rep 264
Corrupt Files from Bimmer America
Also, WinRAR gave me errors for two of the seven parts of the download. Apparently one of the folders didn't contain the actual file when they uploaded. They fixed that by re-uploading the folder with the actual file in it. However, the checksum error when unpacking part 5 persists and I am waiting to see how/if they correct this. I mention all of this as this is not the quickest and easiest of processes even when everything goes as it should and if you happen to get errors from WinRAR when unpacking the files, I would not try to use them to update your nav system until you are sure that all the files are correct. I am trying to get this done before a long trip for Thanksgiving, but at this rate I doubt I will have time. |
11-17-2017, 07:27 AM | #8 | |
1837
Rep 6,990
11-17-2017, 04:16 PM | #9 | |
Ne Plus Ultra
88
Rep 264
Map Updates - Issues
11-17-2017, 04:40 PM | #10 | |
Ne Plus Ultra
88
Rep 264
Problem with Nav Map Updates
11-18-2017, 11:54 AM | #11 | |
1837
Rep 6,990
11-19-2017, 03:05 AM | #12 |
2374
Rep 8,364
There are 13 regions and it is based on ConnectedDrive Profile. You get OTA updates, but rollout has been slow for latest.
You can also update via USB. There is no need to generate FSC as they are preloaded. There are 4 updates a year. Latest for NA is 2017-4. File requires 32+ GB USB to install. You can either install in about 40 minutes or do during multiple trips. |
