10-11-2017, 05:43 PM | #1 |
Rep 60
2018 F36, no aux input?
I haven't seen this mentioned and a quick search didn't bring up any results.
Is the aux input (under the armrest, next to the USB socket) no longer present in the 2018 builds? Thanks. |
10-11-2017, 07:59 PM | #2 |
245
Rep 2,387
USB runs power and audio so no need for an aux jack.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
10-11-2017, 08:09 PM | #3 |
Rep 60
10-11-2017, 08:52 PM | #4 |
343
Rep 1,029
2018 GC no AUX input, just USB... the times of analog audio are slowly going away...
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
tex26702418.50 |
10-11-2017, 08:58 PM | #5 |
Cheapskate
4450
Rep 4,995
Not a GC but I only have USB in my coupe. I was surprised but not really dissappointed. I also can't find the extra power outlet in the passenger's footwell. I only have the one between the cup holders.
10-12-2017, 07:42 AM | #8 |
Cheapskate
4450
Rep 4,995
Nope, I thought it came standard. I never use them so like I said, not really disappointed. Just unexpected. I'd rather have an extra USB jack to be honest.
10-12-2017, 07:47 AM | #9 |
Rep 15
I guess I am old fashioned but I miss the aux input, I like to play Pandora thru the aux rather than the App in the car. I just think the sound is better. I have tried playing it through the USB but could not get it to work.
03-12-2018, 10:56 PM | #11 |
43
Rep 45
Aux In is better than nothing but it's the least desirable signal path. You're basically taking audio that's been passed through the device's tiny (and noisy) headphone amp, and then re-amplifying it. You're also using the device's onboard DAC, whereas with a USB connection the car's DAC handles the decoding and the device's DAC is bypassed.
Bluetooth would be a step above analog aux-in. While it does use a form of compression, the equivalent bitrate is quite high. Pandora, which streams at a relatively low 128 kbs bitrate should sound fine via Bluetooth Audio. Spotify's 320kbs bitrate might sound mildly colored by the BT compression (you'll hear it mostly in the cymbals, which get extra shimmery). Even Tidal at Lossless CD quality over BT sounds decent on the BMW's HK system. But the big surprise to me about the USB connection in my 2018 is that it supports hi res 24 Bit audio at up to a 192 khtz sampling rate off a thumb drive (but not a USB hard drive... not enough power in the port). None of my previous Mercedes could do that. In fact, my 2010 S550 didn't have Bluetooth Audio at all. You got an Ipod interface with an Aux jack, in a car that MSRP'd for $106,000. |
05-25-2022, 08:24 PM | #12 |
BMW4Life
36
Rep 233
Drives: 2018 F30 340i X-Drive
I know this is an old thread, but wanted to share my findings. I have a 2018 F30 and it only has the USB under the arm rest. I wanted to hook my Apple Ipod classic up to it but didn't think it would work since I don't have an Aux-in Port. Well, I plugged it in with the 30 pin connector and then the USB and everything worked on my idrive screen.
Bob Loblah62.00 |
