10-08-2017, 04:00 AM | #1 |
297
Rep 829
Slight shake in steering wheel
On two occasions recently when traveling at just over 80mph I noticed a slight shake in the steering wheel. It hasn't happened on any other occasions before or since even when doing the same speed. What could be the cause?
10-08-2017, 10:45 AM | #2 | |
6659
Rep 15,858
Sometimes this is noticed more as the imbalance gets worse. Go around a slow bend at the vibration speed, the shakes come and go as the wheels go through the different rotational positions. If it is the problem, it will be evident on more occasions in the future. |
10-09-2017, 10:32 AM | #3 |
297
Rep 829
Thank you for your reply. Obviously I thought of balancing. But is it not strange how it has only happened twice and often when I travel at the offending speed it's fine?
10-10-2017, 01:24 AM | #4 |
45
Rep 107
You don't have the driving assistant thingy? If you come close to a lane change without blinking the steering wheel will vibrate
10-31-2017, 08:52 AM | #5 | |
3086
Rep 4,210
Try turning the lane change warning off and see if that does the trick. Alternatively, you could change the intensity setting of the lane change warning. When I test drove a 5 series, the lane change warning was very much discernible at the high setting (I deliberately let my car edge over toward another lane when I had room to see how the warning went). |
