Excessive Oil Use With ST
10-05-2017, 11:34 AM | #1 |
77
Rep 538
So I have a DOC Race 6466 kit - Before running the motor for the first time I put in a full 7L of Redline 5w40.
When I went to test drive it at only 18psi I did about 2-3 hard pulls in 2nd - 3rd gear. Everything was smooth and no leaks were found. The next day I took it to work and drove normally, but on the highway the low oil light came on - Ok. So I added 1L. Later that day I drove home and same thing.. Another 1 L... 2 days later.. yet again another 1L.. I checked my charge pipe to inspect for any oil and it has the typical amount that you would see. However I'm thinking there is probably a large amount in my intercooler now. I'll be pulling that this weekend to check it out, but aside from all of that - What is causing all this blow-by? I'm currently running my PCV vent to atmosphere since I have still yet come up with how I want to route it (Im guessing it could be due to this). Also have the RB PCV. |
10-06-2017, 12:28 PM | #2 | |
Life is better with burnouts
98
Rep 611
Drives: BMW
10-06-2017, 01:10 PM | #4 |
233
Rep 885
This. Make sure you're not overfilled at this point.
DocRace 6266 E92. M8 comp coupe, X5m
10-06-2017, 01:53 PM | #5 | |
3441
Rep 79,211
Also with that potential overfill of oil it can have catastrophic effects on the engine. I'd consider a complete drain and fill and inspect for obvious leaks. If no oil out the exhaust and nothing excessive in the charge pipe it's likely attributed to a bad oil level sensor. (That's my guess). |
10-06-2017, 03:00 PM | #6 |
77
Rep 538
I just started to get an Oil condition/Level sensor code today. My guess is also on this. I'll be draining the oil this weekend and ordering a new sensor. Thanks for the info guys. Will update further on once complete.
10-06-2017, 07:18 PM | #7 |
3441
Rep 79,211
10-09-2017, 02:24 AM | #8 |
137
Rep 589
Drives: E90 M3/E92 M3
Same issue happened to me. 6466 as well. Oil was consuming lots of oil. Turbo was sent back to Precision for inspection/warranty and they said nothing was wrong... I'm assuming it's because of the lack of crankcase ventilation? Just had the heads tapped/plugged and installed RB PCV routed to a Mishimoto OCC. Hope that should do. I did my oil pan gasket and oil level sensor recently as well. Will post for updates.
