thermostat issue?
10-03-2017, 06:46 PM | #1 |
Rep 390
thermostat issue?
hello guys i tried searching on here and google..
i get reduced power, once the car reaches a specific temperature, ran the code and its comes up for thermostat ( dont remember exact code) but if i shut the car and turn it back on the half power goes away and continues to drive fine. i recently did my oil filter housing gasket, and it only stared to occur after this, was there an issue with bleeding the coolant? or is it time to replace the thermostat again? thermostat + water pump both replaced at 60k miles car now has 103k miles thanks! |
10-03-2017, 10:23 PM | #2 |
187
Rep 337
Thermostat codes are only thrown for water thermostats. The oil thermostat is purely mechanical, and won't in itself throw a code. Even if the oil tstat fails, it would just result in high temps and high temp limp codes. No tstat codes.
If you suspect air bubbles in the coolant lines, you've already been driving the car around, so the bubbles would have all gone into the expansion tank. You can open the water expansion tank after the car cools overnight. What is your oil temp showing? Do you have MHD to show water temps? |
10-04-2017, 08:22 AM | #3 | |
Rep 390
i do not have MHD, nor any tune. the temperature gauge in the cluster, reaches normal temperature, just like before the engine codes. its less then the middle point which is what 250? im guessing i should just change the thermostat and go from there. |
