10-03-2017, 03:29 PM | #1 |
Team Zissou
3077
Rep 10,198
Is there a clutch delay valve on the 340?
On my e92 335 there was a clutch delay valve which added some undesirable shift lag to the 6MT. You could buy a modified one to swap in to fix the issue.
Is there something like this on the 340? |
10-04-2017, 04:51 PM | #4 |
61
Rep 156
10-05-2017, 09:20 AM | #6 | |
Team Zissou
3077
Rep 10,198
Do you remember where you read it? When I google it, i find a thread on another forum where someone also says they've read it but I can't find the actual source of this information. If it's true bmw built-in the CDV.... Would the CDV be built in to the master or slave cylinder? If it's in the slave, it looks like it could be modified pretty easily... or if #13 is indeed the CDV then we should be able to modify it no problem. Here are some of the parts: Here's #13: https://www.ecstuning.com/b-genuine-...e/21526864478/ #14: https://www.ecstuning.com/b-genuine-...t/21526795713/ (master cylinder... no picture) https://www.ecstuning.com/b-genuine-...c/21526879477/ Last edited by jpsimon; 10-05-2017 at 09:32 AM.. |
10-05-2017, 09:50 AM | #7 |
47
Rep 693
It was in a forum. Not sure where it was a while ago when I was looking to get rid of it myself.
It does look like #13. It would be great if we could get rid of it or modify it. |
10-05-2017, 03:43 PM | #10 |
428
Rep 707
10-07-2017, 07:36 PM | #12 |
Cheapskate
4450
Rep 4,995
usually you can just remove the line, use a pick to remove the reducer, reinstall and bleed the clutch.
i've noticed sometimes the car jerks pretty hard when i push in the clutch in 1st gear. i thought it was because there was no delay valve. i haven't noticed any issues with shifting or difficulty modulating the pedal. |
10-09-2017, 08:23 AM | #13 |
Team Zissou
3077
Rep 10,198
I have no issues modulating the pedal, but there is noticeable shift lag a lot of the time which feels sort of similar to the e92 before i did the CDV delete. Couldn't hurt to see how it feels removing it. I may give this a whirl.
10-10-2017, 03:03 AM | #14 |
2JZ-GTE
3055
Rep 4,006
If your powershifting you feel a CDV somewhere.
06-18-2018, 04:33 PM | #16 | |||
Team Zissou
3077
Rep 10,198
Someone just responded to my post on another forum. He successfully solved this problem. This is definitely something I plan on doing:
I asked him "Did you have a shift delay when going WOT and say shifting from 3rd to 4th? And if so, did this fix it? Back when I had my n54 there was a noticeable delay when shifting until the cdv was modified." and he says: Quote:
06-19-2018, 02:25 PM | #17 | |
824
Rep 1,584
https://f30.bimmerpost.com/forums/sh....php?t=1486773 |
06-20-2018, 06:16 PM | #19 | |
3597
Rep 10,358
https://www.zeckhausen.com/catalog/index.php?cPath=6562
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
06-21-2018, 09:02 AM | #20 | |
Team Zissou
3077
Rep 10,198
