Moneyshift
09-30-2017, 10:58 PM | #1 |
Rep 24
Moneyshift
Well I've done it folks, I was doing some spirited driving in Mexico and powershifted stupidly from 3-4 (2) without backhanding... I popped the clutch back in in well under a second but not before it probably at least partially engaged, locking up the tires and killing the engine. I figured it would never start again but after getting a jump it started no problem without any weird noises. A month later and I'm still seeing no issues/changes. However I'm not an idiot, a misshift that severe is almost bound to do something and I wanted to get some advice on what I should do. Also worth noting, I got a "timing over retarded" code 2x but I cleared it and haven't gotten one since. If anyone has any advice for me on what to do I'd greatly appreciate it
10-01-2017, 12:46 AM | #2 |
3973
Rep 7,215
If its running fine, whats the problem?
FWIW i did something similar more than a year ago - somehow ended up in 2nd when i meant for 4th. The tires chirped but i quickly pushed in the clutch. There is a maximum rev counter stored in the DME, which i think was like 7800. Never had a single issue since. I swear modern BMW owners are a bunch of hypochondriacs... Drive it and be happy you didnt blow it up! Last edited by hassmaschine; 10-01-2017 at 12:58 AM.. |
desertman1232213.50 e90dum58.50 |
10-01-2017, 08:07 PM | #5 | |
1007
Rep 2,109
Money is still in your pocket, didn't happen!
+1 on Hass's post if it works, no problem. Quote:
10-01-2017, 08:21 PM | #6 | ||
1007
Rep 2,109
10-01-2017, 10:47 PM | #7 |
3973
Rep 7,215
10-02-2017, 10:31 AM | #11 |
3973
Rep 7,215
The dealer wouldn't know how to use it to find the maximum rev counter anyway.
if you get a D-CAN cable from BimmerGeeks they can hook you up with the software. |
11-03-2017, 07:43 PM | #13 |
59
Rep 275
dude I ran my engine without oil for ~15-20 seconds before a track day. 20k miles later i'm still good
edit: I'm sorry everyone i really like to drunk bump old threads
11-18-2017, 07:30 AM | #14 | |
22
Rep 54
Since I've read your reply I've been searching all over INPA but without any luck. And here I thought I already knew most of INPA features My INPA is in german MSV70.0 btw. Last edited by Wally_84; 11-18-2017 at 07:36 AM.. |
desertman1232213.50 rjahl996.00 |
12-22-2017, 12:13 PM | #16 |
Basic Bimmer
518
Rep 935
Drives: E92 328i 6MT ///M
I always thought the "moneyshift" was from 4th to 6th to save money on gas... lol (Probably just because that's how I drive.. I literally use 5th gear once a week at best.)
Sorry to hear about your troubles man.. |
12-26-2017, 08:49 PM | #17 |
Member
30
Rep 115
Drives: Metallic Black 2006 325i
the bpc guys ran their engine at 8200rpm. Probably wears out the bearings a lot more. I'm interested to see what part failed in your dead engine
Fly the BMW.
12-26-2017, 09:06 PM | #18 |
[Oo=||=oO]
1103
Rep 2,470
12-27-2017, 12:55 PM | #19 |
59
Rep 275
12-27-2017, 01:13 PM | #20 |
3973
Rep 7,215
12-30-2017, 02:48 AM | #21 |
Rep 24
for those wondering, a single valve dropped on cylinder 5, I was shocked that the car took so much spirited driving and didnt blow but decided to blow upon startup?
12-30-2017, 04:07 AM | #22 |
Rep 24
detailed teardown: rats got into my car and chewed a bunch of stuff. I drove the car to run a quick errand and it was fine. next time I drove my car (a mere 30 mins later) it started up extremely rough, had an erratic idle, sounded like a 1960's camaro and had a pinging that went up with rpm. firs the mechanic after 3 days of diagnosis found a massive short in the ecu (weird). after the 2 weeks it got to get that fixed they found the car still wasn't running correctly. (note, the ecu, may have blown a while ago as I had battery drain issues) anyways they did a compression and leak-down test and found the dropped valve in cylinder 5, he recommended a used engine over a top end rebuild as if there any issues besides the valve it would probably end up being more than just swapping in the used motor. also hass, no offense but after revving a car to 10k I think its a fair assumption that that's what caused the engine to fail.
