09-28-2017, 06:45 PM | #1 |
1014
Rep 638
any fridge guys out there
Hey help a brother out
Fridge warm, freezer working (bottom freezer) noticed fridge was 17 degs freezer was chock full diagnostics below There are 2 dials in fridge marked fridge - freezer (marked 1-9), fridge's dial starts from 0 and from memory I think thats the defroster, fridge switch turns the fan on ' * Removed all foods * Freezer is fine * Fan in freezer works and turns on/off * in "ceiling of freezer" looks like a small vent that is unblocked * Fridge * Crisper has vents no cold air coming through * Top of fridge VENT (no cold air coming out) no fan behind there either just a vent Took apart as much as I could can't see any blockages Wondering if just leaving it overnight to "unblock any ice will help pics below 1ST PIC freezer 2nd pic top of fridge rest bottom where crisper is |
09-28-2017, 06:59 PM | #2 |
1195
Rep 1,086
Needs a system charge, compressor is failing and can't cool both compartments or coils on back or under fridge are so dirty system is overheating due to lack of air circulation. First thing I'd do is unplug fridge and clean coils with a soft brush - not a vacuum cleaner, because one wrong move with a hose tool can break the coils. Be gentle! Then plug it in, set the dials in the middle of the range, let it run overnight and check the temperatures in the morning. Look for 0 degrees F. in the freezer and 38-40 degrees F. in the fridge. If that doesn't work and your fridge is more than 15 years old, it's probably not worth fixing and you should buy a new energy-efficient model. Just the energy savings over the next 5-7 years should pay for it.
jaye9441014.00 |
09-28-2017, 07:03 PM | #3 | |
1014
Rep 638
Hey man txs for the prompt reply
I noticed the following in the 4th picture that white cover in the fridge is VERY cold when you open the freezer door, there seems to be coolish air coming out of the vent which stops when the door is closed gonna have a look at the coils now Quote:
09-28-2017, 07:58 PM | #5 |
1014
Rep 638
the coils where CAKED in dust, cleaned them switched on
there doesnt again seem to have any cold coming thorugh only when the freezer door is opened so still think I'm dealing with a jam/in the vent ? I think (so I've read) |
09-28-2017, 08:33 PM | #7 |
1014
Rep 638
09-28-2017, 09:03 PM | #8 |
1014
Rep 638
Been doing a lot of reading on this.
need to do some logical thinging here think first is to check 1> Damper control in the below picture the box though I couldnt remove the cover, I'm wondering if behing it is a damper control, I didnt wanna force it. I'm thinking that the top is not getting any cold, because it coming from below, that white box cover is very cold, so I'm guessing that the cold is getting there. I might see about removing the cover in the freezer, to check the coils and fan and see if it is obvious that the damper is viewable from the bottom, The problem may be two fold. 1. coils are frozen over, maybe ice has travelled up and gumed up the damper cover essentially jamming it closed. will try that tommorow |
09-29-2017, 12:17 AM | #9 |
16
Rep 192
Hi mate, I had the opposite problem with my fridge recently. Everything
in the fridge was freezing up. Turns out the little electric motor that operates the damper between the fridge and freezer had stopped working and left the damper in the open position. You'll have to pull out the interior of the fridge to get to it, but, I'll bet that's your problem. |
jaye9441014.00 |
09-29-2017, 06:11 AM | #10 |
1014
Rep 638
txs ABC
I checked the fridge before leaving for work at 5am (so lets say 8 hours) temp got back down to 4 deg's ! Still going to monitor it. but saved having to strip it spoiled food I dont careless about I use the fridge to store my insulin in THANKS ALL |
09-29-2017, 09:02 AM | #13 | |
1628
Rep 1,727
I have a 20 year old Sub Zero that is literally magical. Fruit literally does not spoil in it. Samsung? sure it looks cool, but the components suck
2017 C63 2012 X5M SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i |
paliknight2192.50 |
09-29-2017, 09:31 AM | #14 |
10989
Rep 4,822
I have seen refrigerators with those features but haven't quite figured out why they are needed / valuable.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
09-29-2017, 12:56 PM | #18 |
Long Time Admirer, First Time Owner
18079
Rep 9,381
09-29-2017, 01:23 PM | #19 | |
10989
Rep 4,822
Beer and tonic water Coca cola, gatorade, other beverages that don' look like pear juice Beef (steaks and ground), poultry, deli Cheese (various types) Condiments 1/2 and 1/2 Butter or margarine Trash bags (to throw away much of what's in the fridge) OK I guess I see how it works...
09-29-2017, 03:34 PM | #21 | ||
11828
Rep 15,400
Finland has banned all Canadian talk, so i can't by law comment on the abused milk
09-29-2017, 03:34 PM | #22 |
2983
Rep 6,032
Time to get a new fancy Samsung french door fridge with water and ice service. One of those new ones with stainless steel finish and an app that lets you see inside the fridge from your phone and shop for groceries based on what the fridge tells you to buy.
