BIMMERPOST Universal Forums Off-Topic Discussions Board
      05-16-2008, 11:27 PM   #1
sandyeggo325i
sandyeggo325i's Avatar
65
Drives: BMW e90 | 09 Accord V6 EXL
Saving Gas Myths...
Good article on yahoo...
http://finance.yahoo.com/family-home...s-Saving-Myths
Note the number regarding premium gasoline...what do you guys think?
Sure you want to save gas, but there's a lot of bad advice on how to do it. Some of it makes no difference, and some of it can wind up costing you.
With gasoline prices hitting record levels, it seems everyone has a tip on how to save fuel. Much of the advice is well-intentioned, but in the end, much of it won't lower your gas bill.
Here's a look at a few misconceptions:
#1. Fill Your Tank in the Morning
You may have heard that it's best to fill your gas tank in the early morning while the fuel is cold. The theory goes that fluids are more dense at lower temperatures, so a gallon of cold gas actually has more gas molecules than a gallon of warmer gas.
But the temperature of the gasoline as it comes out of the nozzle varies little during the course of the day, according to Consumer Reports, so there's little, if any, benefit, to getting up early to pump gas.
#2. Change Your Air Filter
Maintaining your car is important, but a clean air filter isn't going to save you any gas. Modern engines have computer sensors that automatically adjust the fuel-air mixture as an increasingly clogged air filter chokes off the engine's air supply.
While engine power will decrease slightly as the air filter becomes clogged, a lack of performance or an increase in fuel consumption will be negligible, Consumer Reports says.
#3. Use Premium Fuel
With prices already over $4.00 a gallon, premium gasoline is a hard sell these days. But a lot of drivers think because their owners' manual recommends premium, they'll get better fuel economy if they stick with it. Really, they're paying more money for nothing.
Even cars for which premium is recommended won't suffer with regular fuel. Modern engine technology comes to the rescue again. When sensors detect regular instead of premium fuel, the system automatically adjusts spark plug timing. The result is a slight reduction in peak horsepower - really, you'll never notice - but no reduction in fuel economy.
#4. Pump Up Your Tires
Proper tire inflation is important for a number of reasons. Under-inflated tires are bad for handling and can even cause a crash. Improper tire inflation also causes tires to wear out faster and to heat up more, which could trigger a dangerous high-speed blow-out.
According to on-the-road driving tests by both Consumer Reports and auto information site Edmunds.com, underinflated tires reduce fuel economy, so proper inflation is key.
But you should never over-inflate your tires. They'll get you slightly better fuel economy because there will be less tread touching the road, reducing friction. But that means less grip for braking and turning. The added risk of a crash isn't worth the extra mile a gallon you might gain.
#5. To A/C or Not A/C
There's no question air-conditioning makes extra work for the engine, increasing fuel use. But car air conditioners are much more efficient today than they used to be. In around-town driving, using the A/C will drop fuel economy by about a mile a gallon.
Meanwhile, driving at higher speeds with the windows down greatly increases aerodynamic drag. As speed increases, drag becomes more of an issue, making A/C use the more efficient choice at high speeds.
At most speeds and in most vehicles, A/C use drains slightly more fuel than driving with the windows down, contends David Champion, head of auto testing for Consumer Reports. "My final take on is that it's very close," says Phil Reed, consumer advice editor for Edmunds.com. "It's hard to measure the difference and every vehicle is different."
The best choice - if temperature and humidity allow - is to keep the windows rolled up and to turn the A/C compressor off. You can keep the fans running to blow in air from the outside, but your car will be as aerodynamic as possible while still letting you breathe. You will save gas, but the fuel economy improvement will be slight.
#6. Bolt-Ons and Pour-Ins
Before you buy a device that's supposed to make your car more fuel-efficient or pour in an allegedly gas-saving additive, ask yourself this: Don't you think oil and car companies aren't doing everything they can to beat their competitors?
If BP could add something to its gasoline that made cars go farther on a gallon, cars would be lining up at the company's pumps. Sure, people would burn their fuel-saving BP gas more slowly, but then they'd drive right past rivals' gas stations to come back to BP for more. BP stations could even charge more for their gas and still sell tons of the stuff.
So if there really was an additive that made gas burn up more slowly, it wouldn't be sold over the Internet one bottle at a time.
Likewise, car companies are already spending big bucks to increase fuel mileage. If General Motors could make its cars go significantly farther on a gallon simply by putting a device into the fuel line, don't think for a second it wouldn't be doing that. GM's car sales would go through the roof.
"There are a number of these gas-saving devices that are generally useless," says Champion.
But drivers who try them will swear they work. In reality, it's probably an automotive placebo effect, says Reed. Buy one of these devices or additives, and you're like to pay extreme attention to your fuel economy and how you drive.
Of course it can't hurt to keep a close eye on your driving habits -- and what kind of car you drive. In the end, that can make the most difference in saving gas.
SG e90 | Black Dakota Leather | ZPP | ZSP | 19" BBS LM Reps | Steptronic
iDrive | Aluminum Trim | Xenon | CF Roundels | 15% Tint
      05-16-2008, 11:42 PM   #2
oct1285
54
Drives: Out of warranty
iono about that regular vs premium one. i think i'll pay the extra for the piece of mind or placebo it gives me. I've been buying premium only for the last 4 years so i just usually pay attention to the premium prices anyway.
      05-17-2008, 02:55 PM   #3
777ER
777ER's Avatar
36
Drives: 2007 328xi
What I don't get is many of them said to avoid hard or excessive braking...i mean how can this save fuel? You can't control the car in front of you.
I fail to see how braking to control speed will cost you fuel...
-Chris
2007 Montego Blue 328xi
Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2
      05-17-2008, 03:01 PM   #4
AndrewAZ
AndrewAZ's Avatar
137
Drives: 335i
Some folks tailgate people on the freeway and constantly hit the brakes and speed up.. By doing that you are wasting more gas vs staying at a safe distance and maintaing a constant speed..
      05-18-2008, 01:20 AM   #5
Kiemyster
Bimmerpost Resident Marijuana Consultant
Kiemyster's Avatar
Trinidad_and_tobago
455
Drives: 320i, 325xi, 335Xi, 335i, M3
my theory would basically be when your driving at highway speeds, your car is in a higher gear, but as long as your RPMs are low on the high gear, you would be using much less gas (hence 7+spd autos). so when you stop, you need to downshift, and accelerate again, resulting in more fuel usage versus just coasting and letting your speed drop...
but hey, what do i know? gas here has always been, and always be 1.25 US a gallon. thats just one favor our government does for us.... they pay for our gas to keep it cheap
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!"
'06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi
      06-12-2008, 02:42 PM   #6
777ER
777ER's Avatar
36
Drives: 2007 328xi
Originally Posted by cars4lyfe View Post
Think about it...whenever you brake you have basically lot momentum and you have to use more gas to get the car moving again. I always coast to stops and I try to anticipate the flow of traffic and keep my van in motion at all time where permissible. This saves gas and brake pads. I used to fill up every week by driving aggressive, but since I implemented the new style of driving, I now fill up every two weeks driving the same distances.
I think this is the easiest way to increase fuel efficiency. It's also easier on the car's parts in general imo.
Try to Accelerate slowly, brake slowly and coast to stops and in general stay a few car lengths behind the car in front of you and maintain that distance w/o braking. So if he slams his brakes suddenly you should have plenty of space & time to merge to the next lane if possible to maintain your speed.
What I meant was I fail to see how it can save fuel like when you have to come to a stop at a light or a car that's stopped in front of you like there's a stop sign.
Other than that, I can understand braking then accelerate again costs fuel but braking alone in itself does not.
Sometimes in traffic, If I let more than 2 car space in front of me, some @$$hole in a van or another car will cut in front of me because my line is moving.
When fuel reached $4+ per gal, I have slowed down and spend a few more mins in my commute to work and back using the CC more often and the end result after 2 full tanks?
I get 45 more miles to the tank....almost enough for one extra roundtrip to work.
-Chris
