09-27-2017, 12:04 PM | #1 |
Rep 61
F22 Mirror Caps
Hi
i was looking to change my mirror caps to carbon fiber black i heard ali express is what people from here go for. Which one did you guys choose? and how easy is it to install ? How are they quality wise? https://www.aliexpress.com/wholesale...r+caps+bmw+f22 https://www.aliexpress.com/item/F22-...8-98bbf789c452 |
09-27-2017, 12:08 PM | #2 |
1165
Rep 1,931
installation is simple.
stand with mirror side in front of you, grip the cover, pull off and down. They snap right off. Use same method to put the new caps on. Buy whichever you want, for the price you can buy another set in a year or two.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
09-27-2017, 03:51 PM | #4 |
313
Rep 525
Yeah, do NOT just pull on it. There are 3 tabs that can break and people have broken it. Also, when you pry the mirror off, use something a little wider so it distributes the force across more area. I know a guy who broke the mirror trying it with a narrow-ish tool.
09-27-2017, 04:29 PM | #5 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
See also the UK AutoID video
https://www.youtube.com/embed/ZuAbyb2RvTo I would recommend also winding-down your window glass so you can perch the mirror on the window sill, rather than hang it by its wires. I was really careful with the first mirror and took at least 15 minutes, but the second one I did in about 5. First time is a bit nerve-racking in terms of clicking the mirror out - don't use anything narrow like a screwdriver: as wide and flexible lever as possible such as the trim tool is best. As above, you have to pinch-in each of the cover clips in order to pull the cover off - you can't just yank the cover off using brute force. Here's how my replacements look:
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) Last edited by msej449; 09-27-2017 at 04:43 PM.. |
09-27-2017, 04:38 PM | #6 |
313
Rep 525
I just draped a towel over the door, a-pillar, and the base of the mirror. That way, when the mirror pops off (I pried from 2 locations simultaneously to better distribute force), it won't hit anything other than the towel.
09-27-2017, 06:58 PM | #10 |
Rep 61
is that too cheap for 28$ ?
https://www.aliexpress.com/item/Side...f-be6d9dd0b33b |
09-27-2017, 07:42 PM | #11 |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
No experience with the Ali Express models, but I can tell you not to go with RW Carbon. They get $199/pair and they clouded and developed bulges after 6 months even with going over and above to maintain them including PPF.
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
09-27-2017, 10:39 PM | #12 | |
147
Rep 148
I popped my mirror glass faces off and used fingers to squeeze the tabs. With how strongly they were on, there’s no way I would have been able to get them off just by gripping and ripping. I wrapped some cloth around 2 wide flat screwdrivers and popped them out. The first one was a little nerve wracking I paid $56 USD for the pair via AliExpress |
09-28-2017, 03:37 AM | #13 |
msej449
514
Rep 717
@weeknd - Mine were made in the UK by AutoID. Current price is £125 including UK postage but there may be a postal charge to the USA.
AutoID UK Personally, I prefer this plain design to the M2 type (the one with the 'wings'). AutoID also offers the winged cover in gloss black and body colours. After about 12 months including a wet UK winter and driving at altitude in the Alps in the summer they look as good as new with no yellowing etc. I was considering doing something funky with the original greys - say black and estoril blue with a narrow, discrete 'M' stripe or something similar. But this is one of those things I'll probably never get 'round to. I had also planned to replace the interior trim with the carbon fibre bits. Trouble was there are so many parts (dash, vents, steering wheel, door handles, centre, shift, gaiter base, handbrake & armrest): once I'd got one I knew that I would want the set. Plus once I had the car, I actually preferred the High Gloss Black standard trim I'd ordered. So that saved a lot of money and effort. What I did do was re-spray the cheap-looking silver gaiter base matt black - removal doesn't involve any electrics or 'once you've started you have to finish' issues so it was pretty easy.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 09-28-2017 at 03:57 AM.. |
09-28-2017, 08:23 AM | #14 |
Rep 61
09-28-2017, 09:00 AM | #15 |
1165
Rep 1,931
you wont brake any tabs. If changed many caps on many bmws, never had any tabs brake off. But do what ever you want.
www.nybmwcca.org
09-28-2017, 09:43 AM | #16 |
4517
Rep 8,942
Broken mirror costs a LOT more than a broken tab. This has been discussed to death through as others have said just do whatever you are comfortable with and move on with your day.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
09-28-2017, 11:45 AM | #17 |
605
Rep 970
I had considered swapping mine out w/ the winged style M caps. Then I read that at speed they can produce a whistling noise you hear in the cabin.
In the end, decided to just leave mine as they are from the factory. |
09-28-2017, 02:15 PM | #18 |
5556
Rep 5,372
I just rotated the mirror around and took a pick tool set to pry the tabs, one by one. Easy job. No risk of breaking anything either.
09-28-2017, 03:32 PM | #19 | |
147
Rep 148
Stickers inside seem to be the same. On one of mine, there was a couple of scratches in the clear coat. Only small, but of course, when you pull it out of the packaging and inspecting it, you are holding it close, and every imperfection seems magnified. The sellers response was to take it to a “body shop” and have them buff it out. I gave it a small go with cutting compound at home, but was more worried about doing damage to the rest of the clear coat, so I left it. Had I bought from a local reseller I would have returned it. I just put that down to “Aliexpress life”. Like how you should anticipate being raped by a taxi driver. Putting the on was such an easy job, that I haven’t even taken any ‘after’ photos. You can sorta see them here. Sorta. If you have an iPad you can pinch zoom I guess. Yes, that IS a carbon rear diffuser (also from Aliexpress). Let’s just say that the mirror caps fit a LOT better than the diffuser. |
09-28-2017, 09:37 PM | #22 |
147
Rep 148
My personal opinion is you are being overly sensitive. If you are after perfection, don't buy a dodgy, half-carbon fiber, non-genuine mirror cap of a site more spurious than ebay. Especially one which is so cheap. There used to be an expression that you get what you pay for.
I didn't go the M-style with the wing, as I thought it would look dicky from the driver's seat. I cant comment on the whistling. As for the scratches, here is a walk around I just took, and tried to highlight the scratch. The mirror is fine Flash OFF Flash ON A shot of the scratch. With the lighting in the garage, its hard to notice it. It is a tiny white line. Tiny. I don't get close enough to my car to notice it. If you do find yourself getting close enough to notice it, please wear a condom. |
