2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Brake Pad Wear indicator
      09-18-2017, 10:50 PM   #1
snaketh
100
Drives: 2015 M235i 6MT
My car tells me my brakes have 3200 miles left. They were checked at the dealer and have 6mm at front and 8mm at rear.
Is the wear indicator that accurate? Seems like a dubious number, does the dealer put that 3200 miles left in my iDrive or is the car that smart?
      09-18-2017, 11:12 PM   #2
pikcachu
pikcachu's Avatar
1398
Drives: M235i (F22 Red angel)
No, it's pretty bogus.
Dealer might even reset the counter according to how much real pad you have left
The sensor will actually trigger when the disc starts contacting with the sensor and then it will show say 500 miles left
Anything before it goes yellow is just some estimation
      09-19-2017, 12:02 AM   #3
snaketh
100
Thanks Picachu, I thought it was BS.
I used to do the pads (and drums) on my older cars myself. Do you know if it's just as straight forward on the 2er? Could it void the warranty if I DIY?
      09-19-2017, 07:59 AM   #4
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
this car is very easy to change pads.
The caliper has 2 small pins you need to knock out from front to back, once out, there is a metal clip on top that holds pads in. once you take the top clip off, use your screw driver to open caliper and pop pads out, put new ones in, put clip back ontop, put 2 pins back in.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      09-19-2017, 11:29 AM   #5
snaketh
100
Sweet, I thought it was easy. Used to do pads all the time on my GTI. Do you know if it invalidates the warranty?
thanks
      09-19-2017, 11:36 AM   #6
bryan_G01
bryan_G01's Avatar
1165
brake pads? nah man...
www.nybmwcca.org
Current Cars:
      09-20-2017, 01:53 PM   #7
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
I like to crack open the brake fluid reservoir too. Relieves pressure in the system when pushing the caliper pistons back. Also good time to check fluid level when you get the new pads in.
Don't take the cap off (don't want contaminants getting in). Just loosen all the way. Don't forget to tighten when done!
BM235iW97.00
      09-20-2017, 02:47 PM   #8
overcoil
3069
Drives: M235i 6spd
anyone use this http://www.racingbrake.com/product-p/ccp01.htm
or instead of a C-clamp a dedicated tool to push back piston when doing pads ?
      09-21-2017, 11:17 AM   #9
cxp213
cxp213's Avatar
313
Drives: M235i
^ I always used a punch to push the pins out and grab it with pliers on other cars.
Dealers can put in an arbitrary value, instead of just resetting it?
Also, if you never triggered the sensor, does this mean you can re-use the sensor when you replace the "not-worn-enough-to-trigger" pads with brand new pads?
      09-21-2017, 02:46 PM   #10
pikcachu
pikcachu's Avatar
1398
I got this https://www.harborfreight.com/hand-t...-pc-62686.html
That's what they said a while back.... i had about 2000mls left and then it started showing 15000...
I guess you could but, I think they recommend to replace it with every pad change.... you can get aftermarket sensors for $10 or so...
      09-21-2017, 03:29 PM   #11
Maynard
3805
Drives: 228iX & M2C
You may want to pull some brake fluid out if there isn't much room above the fill line (at least watch it after each set of pads to be sure you aren't overflowing) - haven't done brakes on a BMW, but in the past it would sometimes overfill the reservoir, spill out in engine compartment where it is impossible to clean fully, and then eats away paint. My buddy had a trick metal 'turkey baster' for this - DK if it will dissolve regular plastic ones.
Appreciate 2
BM235iW97.00
Tpeterson156.50
      09-21-2017, 04:04 PM   #12
bryan_G01
bryan_G01's Avatar
1165
Yes you can reuse the sensor.
I buy mine from FCP euro so when they do break, I get free replacements.
After you do your brakes, you have to reset your service conditions.
Can do this through the dashboard, or buy using a device like bavtech tool.
Steps are available on youtube.
www.nybmwcca.org
Current Cars:
      09-22-2017, 09:41 AM   #13
cxp213
cxp213's Avatar
313
Drives: M235i
Good to know, but yeah I'll probably replace the sensors through FCP Euro. Still need to check them out, actually, but I digress.
I don't think there's any harm in you just taking some out using regular ones, as long as you're not letting it sit in the reservoir for extended period of time.
However, if you're at a point where there's too much fluid, you might as well just bleed out some old fluid.
Maynard3804.50
      09-22-2017, 06:42 PM   #14
MarcoZandrini
439
Drives: 2018 M240i
I stick a screwdriver down against the pads and the rotor and force the pads (pistons, really) back. Doing so won't damage the rotors. Makes the whole process a lot easier. Yes, remove some brake fluid from the master cylinder. I've seen cars dripping brake fluid down the firewall as the person changing the pad didn't remove any fluid. Brake fluid is very corrosive.
      09-22-2017, 08:52 PM   #15
pikcachu
pikcachu's Avatar
1398
well... if you didn't add any fluid, then no matter how much you push the pistons back, it shouldn't technically overflow
      11-20-2017, 03:50 PM   #16
Anthony235
Anthony235's Avatar
715
Drives: m235i
2015 BMW  [0.00]
If I remember correctly the wear sensor is only on 2 calipers, correct? 1 in the front and 1 in the rear.
Pretty sure I noticed this when swapping out my track/street pads.
bryan_G011164.50
      11-20-2017, 03:53 PM   #17
bryan_G01
bryan_G01's Avatar
1165
two sensors only.
And if it breaks and you don't have a new one available, you can twist the 2 wires together to form a loop, that will take the CEL off the dash until you replace.
www.nybmwcca.org
Current Cars:
Appreciate 2
      12-18-2017, 12:17 PM   #18
BEM-S4
BEM-S4's Avatar
4515
Drives: Dinan M235, Dinan Sport Wagon
Not sure if this is the case with yours but on GF 3 series said pads due 1K, there was a S/W glitch where the estimating parameters were wacky and once they updated it said 20k if memory serves.
Yours may have been a similar situation.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      12-20-2017, 06:32 PM   #19
jmwilson125
340
Drives: 2016 M235i
I made this rookie mistake. I was like what the hell is leaking from my belly pan. Then realized it was brake fluid.
I ended up won't everything I could and then dumping a bunch of denatured alcohol down the same area.
      05-14-2018, 07:46 AM   #20
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
604
Drives: 2015 F31 xDrive
two sensors only.
If anyone needs a sensor or two I have some. I didn't know there was only 2 and they don't work with my StopTech pads so I have 1 rear and 2 front spares.
PM me your info. I will send them to you for free. They are just taking up space on a shelf in my garage.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
Appreciate 2
cxp213313.00
      05-14-2018, 12:50 PM   #21
SteveInfante
604
I'm down to 1 front sensor.
cxp213313.00
      06-01-2018, 04:10 PM   #22
Blue2
172
Drives: 2024 M240i
Is it possible to check your brake pads with the wheels on? I tried the straw method but there's really no clearance past the caliper.
Search this Thread:
Advanced Search
2addicts
