BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos
      03-02-2006, 06:05 PM   #1
BMW0
BMW0's Avatar
235
Drives: AW E90 330i
2006 330i  [0.00]
2006 Lamborghini Murcielago LP640
---- Specifications ----
Engine
6.5 liter V12
Torque
487 lb-ft @ 6000 rpm
HP
640 hp @ 8000 rpm
HP/Liter
98.5 hp per liter
0-62 mph
3.4 seconds
(from Lamborghini Press Release) Automobili Lamborghini will present the passionately developed evolution of the Lamborghini Murciélago Coupé at the 76th International Car Show in Geneva.
The new version of this highly successful super-sports car features considerable innovations in terms of body design and mechanics. And also with a new name: Murciélago LP640, which refers to its engine position - longitudinale posteriore - and to its power 640 hp. Designers and engineers have not only focused on reworking the engine, suspensions, gearbox, exhaust system, brakes and electronics, but also the interior and exterior design; improvements that make the Murciélago LP 640 the most extreme and fastest sports car in its class, placing it at the very top.
The first vehicles will be available in spring 2006. Since the original Murciélago’s debut at the 2001 International Car Show (IAA) in Frankfurt, around 2,000 vehicles have left the car plant in Sant’ Agata Bolognese.
Unmistakable Design
In their reinterpretation of the Murciélago LP640, the designers at the Lamborghini Style Centre have remained true to the traditional Lamborghini principles of purism, sport and function. The Murciélago LP640 now appears even more aggressive, with the new front and rear bumpers contributing
significantly to its appearance. The exhaust system terminal has been incorporated in the diffuser on the rear bumper. Other innovations include the rear lights, which enhance the distinguishing features of the Murciélago LP640, making it unmistakable even at night. The design of the sides is also worth mentioning: while the area behind the air intake on the right side is practically closed, the left side features a vast aperture for cooling the oil radiator. Together with the aerodynamically defined front and rear, this proves yet again that the shape of a Lamborghini is dictated by function.
For those wishing to flaunt the heart of their Murciélago LP640, on request an engine hood made of transparent glass can be supplied. The rear view mirrors and the windscreen wipers have been modified to improve aerodynamics and “Hermera” light metal wheel rims have been added. The graphics of the instrument panel lights in the cockpit have been revamped. The interior upholstery
also has a new look thanks to the lozenge-shaped stitching.
More powerful engine
The engine of the new Murciélago LP640 has undergone outstanding and radical modification. The increased bore and longer stroke have boosted the displacement of the classic 60° V-engine from 6.2 litres to 6.5 litres (6,496 cm3). Thus the already extraordinary 580 hp engine power has now been elevated to an impressive peak of 640 hp (471 kW) at 8,000 min-1. The 12-cylinder engine reaches a maximum torque of 660 Nm at 6,000 min-1. Naturally, the Lamborghini Murciélago LP640 complies with every European and North American law governing exhaust fumes.
This “evolutionary leap forward” has been possible thanks to a coherent review of every engine component: the cylinder head and the entire intake system (based on the tried and tested Lamborghini variable geometry system), have been completely reworked. The crankshaft, camshafts and exhaust system have also undergone innovation.
The increase in power naturally determines an increase in performance. The excellent performance of the Murciélago LP640 means it can now accelerate from 0 to 100 km/h in 3.4 seconds (0.4 seconds faster than the previous model).
Lamborghini engineers have also concentrated on improving torque development.The “drivability” of the engine is enhanced by a continuous variable timing system (intake and exhaust side) and a drive-by-wire engine management system.
To meet the thermal requirements of the engine, the engineers have foreseen a considerably larger oil radiator and subsequently, the air intake on the left side of the vehicle has been enlarged. The liquid cooling system, characterised by the Lamborghini VACS system (variable geometry air inlet system) remains the same. Electronically managed air intakes open depending on the outdoor temperature and the need for cooling air, ensuring maximum aerodynamic efficiency.
Gearbox and transmission: improved efficiency and strength
More power and higher torque call for superior gearbox component performance. To meet these new demands, the new Murciélago LP640 features a modified six-ratio gearbox as well as a tougher rear differential and new axle shafts. On request, the e-gear automatic gearbox is also available equipped with the new dedicated “Thrust” (acceleration programme) mode.
Just like its predecessors, the Murciélago LP640 features permanent four-wheel drive, based on the reliable Lamborghini VT (Viscous Traction) system. The system is self-governing and does not feature any electronic controls. The drive force is usually divided between the front and rear axles in the ratio of 30 to 70. An independent control circuit adjusts the distribution of the drive force depending on dynamic oscillation, weight distribution and the relative friction factor in perfect synchronisation with the Visco clutch. In extreme cases, up to 100% of the drive force can be applied to a single axle.
Electronics: a "closed loop" for total control
The electronics have also been updated. The modified engine control units improve engine performance and “driveability” thanks to “closed loop” control.
Every engine and vehicle parameter is managed and controlled by three “master” control units and a “satellite” control unit. The master control units consist of two Lamborghini "LIE" engine control units, a Lamborghini “GFA” (Auxiliary Function Management) control unit and a Lamborghini “PMC” (Power Motor Control) satellite control unit. The control units are interconnected by a CAN Bus line.
Frame and chassis: perfect harmony
The body of the Murciélago LP640 with its characteristic scissor doors is created from the prized union of sheet steel and honeycombed carbon fibre, glued and riveted together.
Driving, handling and stability at high speed are enhanced by new springs and stabilisers, as well as by a redesigned electronically controlled damper. The "antidive" and "anti-squat" features on the axles, which efficiently prevent so-called "brake diving" and "squatting", have not been changed. The two springs on every rear wheel, the single spring on every front wheel and the damper are placed
coaxially.
The new aluminium "Hermera" rims measure 8 ½" x 18" (fore carriage) and 13" x 18" (rear axle). The vehicle can be fitted with various sized Pirelli P Zero "Rosso" tyres. The Murciélago LP640 features 245/35 ZR 18 front tyres and 335/30 ZR 18 rear tyres. For sports use, especially on racetracks, Lamborghini provides optional Pirelli P Zero “Corsa” (Race) tyres. Pirelli P “Sottozero” (Sub zero) winter tyres are currently being developed.
Brakes and safety: optional ceramic carbon brakes
A super sports car such as the Lamborghini Murciélago LP640 ensures high safety levels.
The dual hydraulic circuit brake system equipped with a vacuum brake booster ensures considerable deceleration values. The self-ventilating front and rear brake disks measure 380 mm x 34 mm and 355 mm x 32 mm respectively. The control circuit of the four-channel anti-blocking system (ABS) with electronic brake control (DRP) and traction control (TCS) features a new characteristic curve. The
system consists in an electro-hydraulic control unit and four speed sensors.
When particularly high braking performance is required, on request it is possible to equip the vehicle with 380 mm x 36 mm ceramic carbon brakes featuring six piston brake callipers. Thus, less pressure needs to be applied to the brake pedal and the braking distance is reduced. Even in extremely demanding conditions there is almost no perceptible fading. Considerably reduced weight and superior
lifetime represent two further advantages, as well as a captivating graphic design.
The new Murciélago LP640 also meets with even the most rigorous safety requirements. Thanks to the two front airbags (a 60-litre single stage air bag on the driver side and a 130-litre two stage airbag on the passenger side), the Murciélago LP640 complies with every international law in effect in terms of
head-on and side crashes, impacts against posts, occupant safety, fuel supply integrity and flammability of materials. The luggage compartment also complies with childproof safety regulations.
Interior: even more exclusive and customised
The seats in the cockpit have undergone the most radical changes; more spacious and equipped with redesigned head restraints, the seats now ensure better comfort. The leather upholstery features lozenge-shaped stitching called "Q-citura". The same design is recaptured on the upholstery on the door panels, the panel between the seats and the engine compartment, and on the roof panel.
A new instrument panel has been developed with lights featuring a new graphic design, flanked by a new Kenwood car radio with a 6.5” widescreen monitor and DVD, MP3 and WMA player. An optional navigation system is also available (standard in Japan).
Like its predecessors, the new Murciélago LP640 can be customised thanks to the special fittings and upholstery packages. For the first time, the renowned characteristic Murciélago Roadster asymmetric and driver-oriented fittings and upholstery are available for the Coupé, featuring a perforated leather driver’s seat and door panel.
Thanks to the "Privilegio" customisation program, any Murciélago LP640 can be transformed into a customised sports car. For example, the cockpit can be enhanced with an extremely refined carbon finish applied to the air conditioning control panel, the control lever console and the parking brake.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive"
      03-02-2006, 06:24 PM   #2
aapriadi
aapriadi's Avatar
Indonesia
189
Drives: '13 F30 AW 320i
dark & sexy
      03-03-2006, 05:14 AM   #3
ndox
Drives: E-90 325i
very nice car....so hoootttt hauhea
      03-03-2006, 06:02 AM   #4
325 Baller
325 Baller's Avatar
262
Drives: X3 28i
2006 325i  [0.00]
that car is contagious.
      03-03-2006, 08:53 AM   #5
younghov85
65
Drives: 2006 E90 black 325
It looks nice, but i was never a Lambo man.
      03-03-2006, 09:18 AM   #6
vladinecko
vladinecko's Avatar
277
Drives: '11 E92 M3
2011 BMW M3  [9.00]
2008 BMW 335i  [0.00]
2006 BMW 330i  [0.00]
1994 BMW 325i  [0.00]
man, that looks very futuristic. a perfect family vehicle
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold
2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold
1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold
      03-03-2006, 09:19 AM   #7
vladinecko
vladinecko's Avatar
277
Drives: '11 E92 M3
2011 BMW M3  [9.00]
by the way, anyone ever tried one of those weird gear knobs like lambos have? i mean, just the ball on top, a thin stick going down into the guided gear path. if you did, how does it feel? it just seems a little odd to me in a high end car like that.
      03-03-2006, 10:41 AM   #8
SteveMD
SteveMD's Avatar
193
Drives: 2016 F10 535i MSport
Gated shift.
No 6th to 2nd mis-shifts.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      03-03-2006, 10:47 AM   #9
vladinecko
vladinecko's Avatar
277
Drives: '11 E92 M3
2011 BMW M3  [9.00]
Originally Posted by SteveMD
Gated shift.
yeah, but how does it feel driving it?
plus, if you still do mis-shifts driving a lambo, you have no business being in that car...
      03-03-2006, 12:58 PM   #10
fredtoo
fredtoo's Avatar
15
Drives: 325 328 350
1986 328  [0.00]
2006 325  [0.00]
You don't even notice it.
The shifter really doesn't hit these "guides"
      03-03-2006, 03:15 PM   #11
Ethirtynine
Ethirtynine's Avatar
Drives: 2004 Honda S2000
That car is hot, but.. Ferrari > Lamborghini
      03-03-2006, 03:40 PM   #12
vladinecko
vladinecko's Avatar
277
Drives: '11 E92 M3
2011 BMW M3  [9.00]
are you basing this comparison on your own experience? did you drive both cars? also, both ferrari and lamborghini have different models out, which ones are you comparing?
      03-03-2006, 11:58 PM   #13
flyinbrian
flyinbrian's Avatar
23
Drives: 2011 535i
Originally Posted by BMW0
Ferrari is less than Lamborghini? Your contradicting yourself Ethirtynine. Remember in math class, look at ">" sign as the mouth of the croc eating the lesser number. Hope this helps.
If you do mean Ferrari is less than Lamborghini then disregard this post.
Just for the record, I like both; Lambo and Ferrari.
He is stating lamborghini is lesser and your example is stating that also. Hope that helps.
      03-04-2006, 03:02 AM   #14
Ethirtynine
Ferrari > Lamborghini, as in Ferrari is greater than Lamborghini. Isn't that mathematically correct? I am not contradicting myself because the croc eats the greater number. You're making this more confusing than it is.
Ok so i haven't driven any of these cars (and probably will never get the opportunity to), but I was basing the comparison on personal styling preferences. Also, Ferrari has history of racing but I do not see much from Lamborghini (from what I've seen, though I may be wrong). I didnt mean to offend anyone
      03-05-2006, 10:28 PM   #15
quincy
Guest
n/a
Drives:
No offense BMW0 but it looks like Lambo borrowed this wheel styling from my lawn mower blade.
      03-07-2006, 04:25 PM   #16
BMW0
BMW0's Avatar
235
Drives: AW E90 330i
2006 330i  [0.00]
It's that sharp, this lambo will cut your lawn if you dare.
      03-07-2006, 06:14 PM   #17
Squawks
One of my two dachshunds:
Squawks's Avatar
53
Drives: B6 A4 3.0 Quattro
Anybody even realize that this Lambo has a faster 0-60 time than the Enzo? By 0.1 second. In fact, that's why Lambo even made this model.
Wouldn't surprise me...
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
      03-07-2006, 11:13 PM   #18
krndanic307
krndanic307's Avatar
Argentina
77
Drives: F20 M140
holy shit!!!! ill wack off anyday with this car =P
      04-09-2006, 01:16 PM   #19
nightkhan
Private Woodman
nightkhan's Avatar
163
Drives: 328i, JB, Space Rocket
kinda off topic, but just to clarify for those that are wondering:
A > B means A is greater than B, thus
B < A means B is less than A
so, Ferrari > Lambo is correct in symbology that Ferrari is greater Lambo. If anyone thinks that is incorrect, go back to your old math books (I'll be surprised if any of you still have them) or just search up any math forum for greater/less than signs.
btw....that pic of the lambo is now my wallpaper
Former King of Stock...
E90 325i, Jet Black:
Done with
Current: E92 328i, Sports Package, 335i wheels, Power Seats, BMW Assist/Bluetooth, IPod/USB, heated seats, //M Short Shifter
Future Mods: 19" CSL's, KW V2, 15mm spacer, tints
      04-09-2006, 02:39 PM   #20
3s-a-charm
3s-a-charm's Avatar
135
Drives: 2017 Tesla Model X
2007 BMW X5  [0.00]
Front end looks like a shark!
17 Tesla Model X 90D (I've been converted!)
PAST: 14 Tesla Model S P85D, 16 X1, 13 X5 M-sport, 04 M3 Cab, 08 E92 M3, 08 535xiT, 07 X5 4.8i, 06 E90 325i, 87 E30 325i, 85 E30 318i
      04-14-2006, 12:38 AM   #21
G8Btech
Philippines
23
Drives: E90 325i
      04-14-2006, 07:40 AM   #22
Robin_NL
S0THPAW
Robin_NL's Avatar
8716
Drives: HS M2 Competition
IMHO Lambo manufactures the more beautiful car(Murc Gallardo) vs Ferrari at the moment. The last 'beautiful' Ferrari was the F355.But I love the F430 too. The rest of the club I don't like:Poseurs brand IMHO IMHO. Pity that Lambo builds very expensive AWD 'Audi's'
If you want to race buy a 997 GT3. If you want something special buy a TVR Tuscan/Tamora/T350C
If you want to show off buy a Lambo Ferrari or E90
