09-14-2017, 04:46 AM | #1 |
30
Rep 107
Tyre pressures increasing through the day
Recommended normal tyre pressures for my car are 2.2bar front and 2.4bar back.
On the morning commute to work startup, iDrive shows pressures are 2.1 front, 2.3 back. After 10 minutes of driving they rise to 2.2f/2.4b and after 30 minutes they could go up to 2.3f/2.5b. On the drive back home, pressures are already showing 2.3f/2.4b, and by the time I get home they show 2.4f/2.6b. Is this ok? are they over inflated? Will I get uneven tyre wear? Any advice would be helpful. Thanks
2016 320d M Sport LCI
09-14-2017, 05:01 AM | #2 | |
6659
Rep 15,858
Reading tyre pressures is fine, but easy to get too anxious, as pressures are changing all the time according to use. Ignorance can be bliss. What you are seeing is totally normal. 0.2bar increase, well inside the working tolerance. Remember it is the setting pressures on the door shut placard, not working pressure. We expect increased pressures, allowance is built in with the setting values. If not, we'd get odd wear running all day at the setting pressure. It is one reason I run RFTs at higher setting pressures. I make lots of 12 mile trips, often in the wet, where tyres don't warm much and pressures never get to the ideal working pressure. To prevent odd wear, particularly on the shoulders. |
09-14-2017, 05:04 AM | #3 |
773
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
Air in the tyre expands when warm and contracts when cold.
When the air expands the pressure goes up and vice versa. |
09-14-2017, 05:41 AM | #4 |
3533
Rep 11,292
Because your tyre pressures increase when you're driving, this is why you should NEVER check and top up your tyres at a garage.
Do them on your drive with the tyres cold.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
09-14-2017, 06:05 AM | #5 |
922
Rep 2,559
This. Check & adjust when cold to recommended pressures & leave. The only time I do hot is on track when reducing them for grip.
09-14-2017, 03:07 PM | #8 | |
169
Rep 305
09-14-2017, 03:19 PM | #9 |
10995
Rep 32,881
Fifth gear did a test on this before, said it made no difference on a road car!
hudson012003168.50 nobby81099637.00 |
09-14-2017, 03:35 PM | #10 |
220
Rep 541
One of the Gas laws. If the volume is constant then pressure will change in proportion to temperature. However its not quite true with tyres as they are made from rubber which changes its hardness and volume with temperature. I recall the pressure will change in a tyre about 2Psi for every 10degC change in temp.
This is why in some parts of the world where the temps can change massively in a day or two, tyre pressures should be adjusted. Also never check and adjust tyre pressure when the tyre in the sunlight. I keep one of these in the boot. Great little pump. https://www.amazon.co.uk/P-I-Auto-St.../dp/B00WOT3YM6 |
