Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Help needed on installation issue with android CCC idrive screen replacement
      09-13-2017, 03:16 PM   #1
-DK-
Drives: E91 335i M-Sport
Hi Guys,
Need help,
Bought an android screen for my 2006 e91 CCC idrive.
https://www.aliexpress.com/item/8-8-...311.0.0.y5gs2S
The seller assured me it will work not only with the e60 but also for the E9x
pretty straight forward installation, plug and play harness, only need to move the optic fiber plug from the original connector to the new harness connector from the rear of the HU.
my issue, after i installed, i hooked up the negative battery terminal. the wipers and washer pumps then immediately starts running out of control, no response from the ignition button etc. only way to stop it was to pull the neg battery terminal off.
so i reinstalled the old screen all back to normal, and everything seems good again. i retry'd the installation and same issue.
the seller assured me the unit will work for my car....
i had this same issue before a long time ago when i had my old reverse camera interface box installed, when i didn't have the LVDS shield ground connected...
i could replicate this issue with the standard screen by just pulling out the LVDS connector from the rear of the screen.
or is there something up with my canbus, or optic fiber network..
where do i start?
thanks in advance
Cheers
Dieter
      09-14-2017, 06:20 PM   #2
dreyo27
92
Drives: 2007 335i e92
Picture of the screen? is it touchscreen?
Also do you have JB4 installed?
Sounds like a can bus issue.
