09-11-2017, 09:30 AM | #1 |
14
Rep 117
Wheel adapter
Before I buy the wheels am I able to run this setup on xdrive with 5x120 bolt pattern? Have anyone used wheel adapters before?
Bolt pattern:5x114.3 F: 19x8.5 235/40/19 R: 19x10 275/35/19 |
09-11-2017, 10:14 AM | #2 |
114
Rep 243
I'll start off that I never liked adapters. Added complexity, added cost, added problems.
Without knowing the offsets nobody will be able to tell you. You'll need a high offset on those wheels so you can also fit an adapter in there. What are the offsets? |
09-11-2017, 10:16 AM | #3 |
14
Rep 117
Front 32 and rear 42
09-11-2017, 01:02 PM | #4 |
114
Rep 243
I doubt you'll be able to make that work. You're already extending 1cm more than stock with just those wheels not counting the thickness of whatever adapter plate you'd have to add in there.
09-12-2017, 12:31 PM | #5 |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Yeah, definitely won't work. Don't waste your time and buy wheels with the proper bolt pattern.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
