09-11-2017, 06:32 AM | #1 |
266
Rep 922
Brake fluid
I would need it for "fast" road driving, not track use.
Which one are you guys using? How much is required? Am I correct in understanding DOT 4 should be fine? I have the M Sport Plus brakes, that doesn't include stainless steel braided brake hoses does it? Any particular ones you guys advise?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
09-11-2017, 06:47 AM | #2 | |
1983
Rep 3,216
TouringPleb4371.50 |
09-11-2017, 06:49 AM | #3 |
266
Rep 922
Ok, perhaps I am overthinking it, but please, humour me
09-11-2017, 09:30 AM | #4 |
1774
Rep 3,490
09-11-2017, 09:31 AM | #5 |
1774
Rep 3,490
Go on then.....
http://www.demon-tweeks.co.uk/Product.do?method=view&n=1714&p=39552&d=124&c=4&l= 2&utm_source=Google&utm_medium=Base&utm_campaign=B rake%20Fluid&gclid=Cj0KCQjw6NjNBRDKARIsAFn3NMoa9iU _IoRFwWSnAg3dA0pPG3WNJejHr4H7FW2b3mFSMB8PGVq6BZkaA jU6EALw_wcB&gclsrc=aw.ds |
09-11-2017, 09:33 AM | #6 | |
266
Rep 922
Can someone please answer the questions I've asked, since I didn't ask if I'm over thinking it?
09-11-2017, 09:41 AM | #7 |
1983
Rep 3,216
Nobody is answering your question because probably nobody has done it. And they haven't done it because nobody has found the NEED to do it - because people don't drive like they're on a racetrack when they're on the public highway.
Unless, of course, they're some chavvy wanker racing round the roundabouts in Birmingham. I'll put it like this : standard brakes (not even the MSport brakes) are perfectly good for the police 530d motorway and pursuit cars. If you need more than that, then some advanced driving lessons would probably be of far more benefit than fitting braided brake hoses and 'race-spec' brake fluid. |
09-11-2017, 09:46 AM | #8 |
266
Rep 922
Ok, that's fine, that's all I needed.
Also, I didn't ask for "race-spec" fluid, I specifically said "not track use". I am due my 2 year fluid replacement, and I like to know if I can use good quality items, that may also help my road experience. Standard brakes, for me anyway, are not good enough. That doesn't mean I drive like a chavvy wanker.
aps335.50 |
09-11-2017, 09:50 AM | #9 |
266
Rep 922
So apparently 1 litre should be enough. I'm going to go for either Motul RBF 600 or Tarox's own DOT 4 brake fluid.
Will try Tarox's brake hoses.
09-11-2017, 09:51 AM | #10 |
2472
Rep 4,653
Goodridge braided hoses, some decent DOT5.1 fluid and EBC yellow pads are enough for some spirited driving
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
09-11-2017, 09:52 AM | #11 |
266
Rep 922
Thanks Steve.
Any real difference between DOT4 and DOT5.1, apart from the -40degC?
09-11-2017, 10:14 AM | #12 | |
1983
Rep 3,216
If they aren't good enough for you, then I think my earlier description stands. Remember, any idiot can drive fast enough to get themselves into a crash. |
09-11-2017, 10:59 AM | #13 |
266
Rep 922
Oh jeez, sure, ok.
I'm used to good brakes, on my Corrado VR6, to my GTR and other various cars. You can stick to your opinion, good for you.
09-11-2017, 11:31 AM | #14 |
6420
Rep 8,500
I use ATE Dot4 in my car. Works very well with StopTech brakes and braided lines : stands-up well on track evenings, with no boiling of the fluid.
5.1 is high maintenance because it absorbs moisture at a faster rate and needs replacing more frequently. As with most things, think about what you need/want and pick products accordingly.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-11-2017, 11:35 AM | #15 | ||
6420
Rep 8,500
Increased braking capabilities are invaluable. You can try and predict road conditions all you like, but there's plenty of room for improvement beyond BMW standard brake setups.
09-11-2017, 11:59 AM | #16 |
266
Rep 922
Watsey, appreciate the advice. I think DOT4 is what I need.
I don't want to go for whole brake kits. I'll use these M Sport until next summer. If I'm satisfied then fine, otherwise I'll go with my tried and tested brand, Tarox. |
09-11-2017, 02:35 PM | #17 |
6420
Rep 8,500
No problem. I've also tried EBC Yellow Stuff pads in BMW brakes but didn't really rate them. OK for moderate fast road use but personally I'd go for something with a higher heat rating - perhaps Ferrodo DS2500. Plenty of choice out there.
09-11-2017, 03:02 PM | #18 |
266
Rep 922
I've always had good experience with Tarox F2000 discs with the Strada pads, seem to cope with my requirements. That combination will be next step.
09-11-2017, 04:55 PM | #19 |
76
Rep 181
Always used ATE SL6 dot 4 fluid.
They have a racing version with a slightly higher boiling point --- http://www.ebay.co.uk/itm/ATE-Super-...-/281442303870 1 litre does a change. |
09-11-2017, 05:10 PM | #20 |
266
Rep 922
Thank you Flyboy777.
09-11-2017, 05:12 PM | #21 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Before I got my Alcon BBK I ran with braided hoses, EBC yellow stuff pads and some Motul RBF600 I think it was. Helped a bit and never had an issue on the road. Helped a bit on track, but not enough, as the brakes still went long and soft after just a few hard laps.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
09-11-2017, 05:19 PM | #22 |
266
Rep 922
On track, are you still using Motul RBF600?
