09-09-2017, 04:43 PM | #1 |
80
Rep 694
LED rear indicators
Has anybody bought and coded rear led indicator bulbs ? I've fitted mines for a couple months and occasionally get a rear indicator failure and it starts flashing double the speed ( normally when a bulb is out) but the indicator is still on.
I have coded the below and still getting errors Rear Turn Signals: All of the codes listed can be found under the REM module. 3061 FRA_H_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Left Turn Signal. 3061 FRA_H_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Left Turn Signal. 3061 FRA_H_L_IS_LED -> aktiv : Setting Rear Left Turn Signal type to LED. 3061 FRA_H_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Right Turn Signal. 3061 FRA_H_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Right Turn Signal. 3061 FRA_H_R_IS_LED -> aktiv : Setting Rear Right Turn Signal type to LED. |
09-10-2017, 06:17 AM | #3 |
451
Rep 1,201
Is there an option code for LED indicators? I wondering if it would be better to change / add the option code then VO code just to mop up any missed code settings. Just a thought, I've not looked into it and may not be possible but if you can, it will be much cleaner.
What do you think teaston ?
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
09-10-2017, 08:48 AM | #4 |
80
Rep 694
The bulbs are Samsung ones, they were fine for the first few months.
When the failure comes up, if you cancel the indicator and put the indicator back on again its fine |
09-10-2017, 09:18 AM | #5 | |
10995
Rep 32,881
stu14t450.50 |
09-10-2017, 10:45 AM | #6 | ||
80
Rep 694
09-10-2017, 04:01 PM | #8 |
80
Rep 694
09-10-2017, 04:04 PM | #9 | |
10995
Rep 32,881
I did code rem for the led reverse bulbs I fitted though. |
09-11-2017, 11:46 AM | #11 |
10995
Rep 32,881
09-11-2017, 05:40 PM | #12 |
61
Rep 156
Will have to check again...
I have Carly, and was well expecting to have to code them, but I've not noticed them do their canbus check flash. I did check this when I fitted them too... |
