09-07-2017, 03:51 PM | #1 |
60
Rep 214
Towing with an X3
Looking to replace my M235 and old Dakota with one vehicle. Must be able to do light towing up to the limit of the factory hitch (3500 lb). For this reason I was leaning towards the GLC with air suspension that auto levels by changing effective spring rate. But MB is determined to so screw up their options this year I can no longer get any of the combos I like.
If I get an X3 how do they tow with 3k lbs behind them? Does the back really sag?
Brandon
09-07-2017, 04:30 PM | #2 | |
4719
Rep 2,526
As this will be the first X series with a factory-installed option (I think I'm right on this), then I think they will have designed the G01 well enough to incorporate the rear end loads that might not have been considered in the previous versions. My take only, but I'm glad they are finally offering such! |
09-08-2017, 06:14 AM | #3 | |
136
Rep 285
Drives: 22 750i
09-08-2017, 02:01 PM | #4 |
60
Rep 214
Yes but the factory hitches are Class 2, so 3500 limit.
Brandon
09-12-2017, 02:26 PM | #5 |
20
Rep 49
No trailer hitch in M40i?
Dealer was able to place my order however he cannot add trailer hitch. States either order guide is wrong and cannot get it on M40i or hitch is not yet available for M40i. He will check again when order goes to 150 status. Currently its 111 status. I sure hope I can get it.
09-12-2017, 04:01 PM | #6 |
4719
Rep 2,526
Same information I received a few weeks ago as well, Headwind. I've been a little busy with Hurricane Irma so haven't had a chance to inquire recently, but will. I suspect since this is the first X to be getting the factory-installed hitch that there may be a few glitches with the ordering but not sure why with current software abilities. If anyone finds out, please share.
09-12-2017, 07:02 PM | #7 | |
866
Rep 6,248
09-15-2017, 04:34 PM | #8 |
4719
Rep 2,526
Re: the trailer hitch on the M40i
It is now my understanding that initial production runs of the G01 X3 M40i allocated to Dealers (which our order is) may be too early for the trailer hitch option. It will be done - just not for these initial models off the line. We have made the decision to proceed with our order without the trailer hitch so as not to lose our early production placement, and will probably get one factory-installed when we trade in our other X3 35i for another M40i next year. Either that, or we can consider an install on this one once we have it.
09-15-2017, 05:00 PM | #9 | |
136
Rep 285
Drives: 22 750i
09-15-2017, 07:30 PM | #11 |
4719
Rep 2,526
Yes, I think those in the Order Status 111 can opt to add one. We were given that option but that would have delayed us at least 4-6 weeks, and I'd really like to trade our 2012 in as soon as possible. We're at OS 112, so that group of production vehicles is probably the batch unable to add the hitch. Right now, for us, earlier receipt of our X3 M40i is more important than the hitch, but we'll be getting it on the next one for sure.
09-29-2017, 03:10 PM | #12 |
597
Rep 1,805
so do we know if it's 3500 or 4400? I couldn't find anything on the specs section bmwna.com
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
09-29-2017, 03:31 PM | #13 |
597
Rep 1,805
Where did you get this info?
Everything I'm reading calls for a 2 inch receiver with 4,400 pounds. Class 2 seems fairly small for the weight and wheelbase of the x3... but I could be wrong. They could throw a class 2 hitch with 2inch receiver to be on the safe side.
10-01-2017, 10:52 PM | #14 | |
60
Rep 214
Brandon
10-01-2017, 11:06 PM | #15 |
60
Rep 214
I might be wrong about the MY18. From the literature I see 2" mentioned and 440 lb tongue weight. Both are above Class 2 specs although there is no requirement that a Class 2 can only be 1 1/4". Still the tongue weight it is more than C2 spec, although less then C3, I suppose because it was at the limit of the vehicle already. Looks promising. I'm probably getting an SQ5 so kind of a bummer since I'm positive that is only Class 2.
Brandon
