09-02-2017, 09:49 AM | #1 |
834
Rep 2,114
Shifting rev blip/hang issue - sounds clip
I am having some issues with shifting. Basically when I accelerate full throttle up to 40 in 2nd then put the clutch in to shift up to 3rd the engine seems to boost even though there is no throttle being applied. Sounds like revs spike but looking at the tach they seem to hang rather than actually increase.
Happens in first a LOT shifting to 2nd but also 2nd to 3rd at around 40mph. A few times it's done the same thing when full throttle and then lifting off completely without pressing the clutch. When pressing the clutch it happens quite frequently. 2 min sound clip with plenty of 2nd to 3rd shifts at 40mph, some are fine, sometimes you hear that blip after the shift. Happens at around 50s and 1 min 25s amongst others. Car is a manual m140i. Any ideas? Back to dealer? https://clyp.it/dv4o4wz2 |
09-02-2017, 11:50 AM | #4 |
3489
Rep 9,709
09-02-2017, 12:13 PM | #5 |
834
Rep 2,114
The rev matching isn't working properly then I guess? I've had this happen just flooring it then lifting off without changing gear or engaging the clutch, not convinced that's the issue.
09-02-2017, 04:16 PM | #7 |
3489
Rep 9,709
Yes DSC turns of rev matching, so probably not that then.
Didn't someone else have issues with wayward revs on a manual 140i? K44ent ??? Last edited by NISFAN; 09-02-2017 at 05:51 PM.. |
09-02-2017, 04:32 PM | #8 |
834
Rep 2,114
09-02-2017, 04:37 PM | #9 | |
3489
Rep 9,709
09-02-2017, 04:42 PM | #10 |
834
Rep 2,114
09-02-2017, 05:03 PM | #11 | |
3489
Rep 9,709
It's not the first time I've heard of odd rev control behaviour from a manual M140i, but whether what yours does is typical or not is the real question. Does it interfere with your driving? |
09-02-2017, 05:11 PM | #12 | |
834
Rep 2,114
10-30-2017, 01:36 PM | #13 |
346
Rep 378
Interestingly enough I am having a similar issue with a 340i I just took delivery of.
Regardless of drive mode, the car seems to blip the throttle after the clutch is depressed on an upshift (and yes, my foot is off the accelerator prior to depressing the clutch). So far I've only noticed it from 3-4 and while accelerating hard, but it's been consistent under those conditions. I've had the car two weeks so who knows... I don't notice it on 2-3, 4-5 or 5-6...
/// F80 M3 CS ///
10-30-2017, 04:47 PM | #14 |
200
Rep 542
Do you have the torque & power meter displays in the Technology options?
What do they do when shifting. I noticed on the 335d, when using the paddles to change down, you can see the torque blips up. (Speed matching?). I was trying to use manual change down to emulate changing down with a manual box, to reduce braking. But it doesn’t work very well. Not the same situation for you, but maybe it will give you a clue?
335d xDrive
10-30-2017, 05:03 PM | #15 | |
346
Rep 378
I know those meters are "fake" but if they're based on engine speed then I'd imagine they'd also jump when the throttle surges... not sure what conclusion to draw either way. (They do blip when the car rev matches on the downshift.) I'll report back.
/// F80 M3 CS ///
Conr4d27.50 |
10-31-2017, 02:29 AM | #16 |
2021
Rep 1,926
MattOz had a rev-hang issue with his manual F31 335i. It is emissions related and sounds exactly as you describe.
He can fill you in on the details
F31 340i | GS with CR & Ash Grain Trim | M Sport+ Pack | Prof Media Plus Pack | Interior Comfort Pack | Leather Dash | Folding Mirrors | Pano Roof | Elec Mem Seats with Lumbar | Adaptive Suspension | Comfort Access | Reverse Cam | Surround View | SLD | Rear Sunblinds | Folding Headrests | Model Designation Delete | Trim Designation Delete | MPPSK
10-31-2017, 09:02 AM | #17 |
346
Rep 378
I'd be interested to hear more...
/// F80 M3 CS ///
10-31-2017, 11:16 AM | #18 |
834
Rep 2,114
It's the laggy fly by wire throttle imo. I've solved it by moving slightly further away which makes me fractionally slower to engage the clutch. Sometimes if my feet get a bit lazy it happens but it's a lot less often.
10-31-2017, 12:00 PM | #19 |
265
Rep 424
I've experienced exactly the same on my last two (non BMW) turbo petrol cars. It's wasn't fly by wire and it wasn't rev matching.....it was however bloody annoying! I think it's something to do with the MAF (not reading the air flow/temp properly?), but it's a total guess tbh. It went away for a while after cleaning though and it doesn't cost much to clean a MAF. No ides if it was actually this or if it affects diesels the same though
10-31-2017, 12:14 PM | #20 |
346
Rep 378
Laggy throttle makes sense... I've been paying more attention and have been noticing that even at low RPM shifts under light load the revs hold slightly even after my foot is off of gas and onto clutch.
I'm thinking that at high RPM and high load the effect is simply pronounced?? I'd be concerned if it was really over revving but it's "only" 100-300 RPM, I'd say. I've also experienced pressing the clutch prior to having my foot fully off of accelerator and that's a much more pronounced over-rev experience. (This is my first 6MT... it happens... )
/// F80 M3 CS ///
12-11-2018, 11:59 AM | #21 |
Rep 8
I experience it too in my 340i rwd 6spd, pretty much every time i rev up to ~5000 rpm, shift up, and pop the clutch (without foot on gas pedal). Revs stay higher than they should be to mesh the tire speed with the higher gear, causing car to surge forward noticeably. A bit discerning at first, if you meant to eventually maintain/slow down after up shifting.
I haven't tried it with rev-matching disabled, or in another older 335i without rev-matching, which would theoretically point the finger at the rev matching "feature". |
