09-01-2017, 05:32 AM | #1 |
14
Rep 75
Diesel Fuel Cleaner Good / Bad?
To some that very sentence would make then sick
Does anyone use the additive you put in your fuel tank when you fill up? I've used it before on older petrol cars but never a diesel and nothing newer than the 2013 320D i have now What are peoples thoughts on the additive and using it?
09-01-2017, 05:35 AM | #2 |
2472
Rep 4,653
Yep I use it - not sure if it actually does any good but I guess for me I feel better doing it
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
F30Andy1774.00 |
09-01-2017, 05:36 AM | #3 |
2472
Rep 4,653
Or just use some premium fuel like Shell VPower etc
Steve Roberts UK
09-01-2017, 05:38 AM | #4 |
1983
Rep 3,216
I don't use it - but I ONLY fill up with Shell V-Power diesel, which is reckoned to have the cleaning additives already in it.
A few weeks ago my wife filled the car up, and I noticed it seemed a lot louder and more coarse on idle / low revs. When I asked her, yes, she'd filled it up with 'normal' diesel. A couple of tanks of premium, and it's back to being a lot quieter. |
09-01-2017, 05:41 AM | #5 |
14
Rep 75
Cheers guys, may give it a shot when next filling up ill use the famous words ( cant see it doing any harm!!!) lol
See if it helps any Appreciated
09-01-2017, 05:46 AM | #6 |
313
Rep 570
I used Millers on an older tdv6 and swore by it, to sum its snake oil, to others it works - Frankly you pays your money and takes your choices, ill unlikely use it on the 335 but ill aim to fill up at shell and ill be changing the oil every 10k.
335d XD Shadow Edition - Mission intergalactic mileage underway
09-01-2017, 05:49 AM | #7 |
811
Rep 1,847
I added a tank of BP Ultimate diesel once and the only difference I noticed was the 26p a litre extra it cost me.
Every mile I drove I was annoyed how much money I had wasted. Saying that I would consider adding a cleaner when the car had a few more miles on it. I don't honestly think fuels are so unrefined in the UK that a cleaner is as vital as some other countries |
09-01-2017, 05:50 AM | #8 |
2119
Rep 3,066
A few of us have used Archoil 6400D injector/fuel cleaner admittedly on 330d's did seem to make a perceived difference but not sure really.
Watsey did an interesting exercise and took his DPF apart having used this cleaner and run it on Ultimate or similar & apart from some soot it seemed clean! Give it a go can't do any harm as long as you follow the distructions ! |
09-01-2017, 06:25 AM | #9 |
283
Rep 797
I've used Forte Advanced Diesel Formula treatment on VAG diesels in the past and never had any problems. Subjective, I know, but they did seem to run more smoothly as a result. It's not available over the counter, but Amazon/eBay have it.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
09-01-2017, 09:07 AM | #10 | |
6416
Rep 8,500
Archoil once or twice a year. BP Ultimate plus Millers every tank. EGR looked pretty clean. There are many variables in terms of fuel, driving style, roads and speeds driven, etc, and whether the car will be a keeper. The combination I use seems to work, so that's what I've stuck with for the past 20 months or so. Costs a bit more than the cheapest option, but supermarket special makes the engine run really rough. No thanks.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
09-01-2017, 11:32 AM | #11 |
325
Rep 709
Archoil 6400d or BG244 which you can get from the Power Enhancer website.
With both products add to a near empty tank prior to filling up. The car will feel instantly more powerful due to the very high cetane with the cleaner. Unfortunately you now need to make the tank as long as possible so that it can dissolve all the build up, so to don't be tempted to give it a spanking. When you get to 1/4 tank refill and drive as normal. I've had great results with both products but now use just Archoil 6400-d as I can buy it in 5ltr containers which works out cheaper per application. |
09-01-2017, 11:36 AM | #12 |
325
Rep 709
Watsey, I use the Archoil annually too but just Tesco finest diesel. No rough running and negligible difference in mpg.
I've ran the premium fuel for a few tanks and only real difference was the cost |
09-02-2017, 03:33 AM | #13 |
110
Rep 331
I've used Millers ecomax cetane booster for the last 30k miles, a few extra mpg but the biggest benefit is the reduced diesel clatter
Cheers
Current: F30 335d xDrive M Sport Plus
18" PZero - 405Ms - ACS Springs - Eibach 16mm ARB - Indigo GT Remap |
09-02-2017, 12:51 PM | #16 | |
169
Rep 305
09-02-2017, 01:23 PM | #17 |
6416
Rep 8,500
Yes, and BMW sells own brand fuel additives, and premium fuels have additives...
MattRST109.50 |
09-04-2017, 08:24 AM | #21 |
14
Rep 75
Just a quick add here guys when i have looked around the net
Not sure if anyone else has seen this but BMW do there own additives for fuel? http://www.baronsgroup.co.uk/bmw/bmw-fuel-additive So there must be something in it if BMW have there own to use in their Petrol and Diesel engines!
JLR19691882.00 |
09-04-2017, 01:17 PM | #22 |
220
Rep 541
http://www.ebay.co.uk/itm/Archoil-AR...53.m1438.l2649
Been using this on mine. I have a tuning box. Was getting a tiny bit of soot out the tail pipes. Clean as a whistle since using the additive. It works out much cheaper than running V=Power. |
