08-27-2017, 04:53 PM | #1 |
218
Rep 492
External boot release?
The external boot release (i.e. the handle above the number plate) on my GC does not seem to be working - if pressed, it clicks but nothing happens. I can still open and close it using the dash button, key fob and the tailgate button, just not the external boot release. Is this some setting I have accidentally triggered or it is simply that e.g. a microswitch has failed and needs replacing?
____________________
Current: Macan GTS Previous: 440i GC, M135i, E60 M5, Z1, 330d, 135i, Alfa 156 GTA, Mercedes 500E, Audi S3, Audi A3 quattro, VW Golf GTI 16v |
08-28-2017, 02:51 AM | #2 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
08-29-2017, 09:09 AM | #3 |
218
Rep 492
Yes, I tried that but couldn't instantly see anything other than an option to alter the height to which the automatic bootlid opens.
09-20-2017, 09:12 AM | #4 |
218
Rep 492
*Bump*
Before I take it into BMW for a check, anyone else got any thoughts on this?
09-21-2017, 02:56 PM | #5 | |
86
Rep 149
Is the engine on? Also, I think then you're in the reverse mode it won't let you open the boot. If it happens when the engine's off and you're in neutral it might be something wrong. I didn't see any setting in iDrive for that. Only one for setting up the opening height, same as you found. |
10-13-2017, 10:41 AM | #6 |
218
Rep 492
So, to come back to this, a 4-series owning acquaintance solved it for me - apparently the factory settings are such that the external boot release will not work if the ignition is on. You don't need to have the engine running, but if the electrics are on, then the external boot release on the hatch is automatically deactivated (but not the internal button or the keyfob button) to prevent theft by passers-by apparently.
Seems odd but it's true. The external release works perfectly with the ignition off and refuses to work with it on.
