08-22-2017, 02:10 PM | #1 |
27
Rep 66
Tires/Wheels in New England Weather
Hello fellow New Englanders,
I just bought an M3 (coming in October) and considering purchasing snow tires. I am currently looking at 245/40R18 97R Nokian Hakka R2s. Two questions: Is this an optimal size for an M3 car? I want thinner rather than thicker tires. Also, what wheel would anyone recomment? And finally, how are these in snow? Anyone have direct experience? |
08-23-2017, 08:32 AM | #2 | |
66
Rep 395
08-23-2017, 10:05 AM | #3 |
913
Rep 1,427
I went with a 245/45/18 all around, Michelin x-ice. I also got the cheapest 18x8 rims on tirerack, rial p-10. Both have been great and held up very well over the past 2 winters. I've read that R2s are an even better tire than the x-ice so you shouldn't have any problem with them.
08-23-2017, 03:58 PM | #4 |
27
Rep 66
08-25-2017, 06:29 AM | #5 | |
346
Rep 366
08-25-2017, 10:27 AM | #6 |
27
Rep 66
Would 245 tires be ok?
What about 17 inch tires??? Would those fit? I am getting a bit paranoid cause I want to order tires before cars arrived in early October and they are on sale now. |
08-25-2017, 11:03 AM | #7 |
27
Rep 66
08-25-2017, 06:27 PM | #8 |
132
Rep 727
OP, I just did a quick look on The Tire Rack's website. It appears 245 would be okay (as well as 255). Though I didn't see an option for 17" rims. I suspect there might be an issue with brake clearance.
Even though I had my M4 last winter, it was kept in storage (as I had a better DD for that duty). |
08-25-2017, 08:00 PM | #9 |
129
Rep 397
Drives: 2019 M4
It really boils down to how much snow you're expecting to drive in. It's unlikely you're going to tackle really deep snow (ground clearance), so what kind of snow conditions do you usually find yourself in. Definitely go 18". Then if you think the bulk of your driving is on plowed roads or an occasional run in fresh snow, I'd suggest a performance winter tire. Square 255/40 works well. If you think you're going to see more significant snow, then a 245 snow might be a better choice. I had the BMW package 640M with the 255/40 Contis. They did a great job. Sold them last year as I have become a snowbird. Check the classifieds.
2019 M4 Coupe MG SS DCT ZCP
2015 M4 Coupe MG SS DCT (Trade) 2009 335xi Coupe Dinan Stage 2 (Sold) 2003 M3 Coupe (Sold) 1998 M3 Sedan (RIP) |
08-25-2017, 08:03 PM | #10 |
X3M Comp
444
Rep 718
Ran the m4 with 18s 255 all around with Blizzak LM60. No issues.
Going to run this year on 18s 245 either size will work. Generally in snow the thinner tire is better but both will work. Just remember slow inputs to throttle and brake and you are all set. Don't sweat it this car with snow tires is no issue in snow. |
08-29-2017, 02:24 PM | #12 |
775
Rep 1,498
Drives: 2017 MB C63 S AMG Coupe
Ran 235 front 255 rear snows on my f80..they were perfectly fine. As long as you modulate the throttle winter won't be of any issue to you.
If you wanna slide than foot to the floor
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330 |
AIRHEIR443.50 |
08-31-2017, 08:24 AM | #13 |
27
Rep 66
Thanks guys,
You made me feel better. I will pronably go with 245/40 R18 Nokians, I heard there is nothing better on the market. I hope M3 on those Nokians will not be worse compared to my civic on all season. Cause if that's the case, I am screwed!!!! |
09-05-2017, 08:38 AM | #14 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
A car with proper snow tires beats a car with all seasons
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
09-05-2017, 12:32 PM | #15 |
314
Rep 2,448
M3 in winter is amazing and f80 is easier to drive in snow than my previous e92 m3 with the active diff.
Most of us up north (Canada) drive this car all year even with other cars to punt around. This isn't an exotic to put away for one season and the depreciation alone fm just sitting there without use makes no sense to store. Running blizzaks on 18, 255 squared. |
09-06-2017, 12:50 PM | #16 |
20
Rep 71
For my winter set-up I picked up a set of blacked out e92 220M's with Blizzak tires. I'm running 235/35/19 Fronts and 265/35/19 rears.
Figured it was better to get a set of wheels that could get beat on a bit with all the sand, etc. They run awesome for me, no issues whatsoever. A bit louder on dry pavement for sure, but worth the trade off when the freezing temps hit and the snow starts falling. B. |
09-29-2017, 07:35 AM | #17 | |
21
Rep 52
09-29-2017, 08:29 AM | #18 |
3514
Rep 2,005
Drives: BMW M3 2024 Brooklyn Grey SOLD
In Montreal, ran the Nokian?s last winter and had no problem. Lots of slush and ice and no white knuckle experiences. I used to run Blizzaks and Nokian are much better.
09-29-2017, 11:48 AM | #19 | |
66
Rep 395
IF anyone has a set they aren't using that has the TPMS installed and it fits the F80, PM me. I have been having a hard time finding a decent used set that will fit the F80s. If I don't find something I'll end up swapping the tires out in spring and fall. |
10-03-2017, 05:50 AM | #20 |
Rep 10
This is what the BMW winter package with contis looks like on my M4.
https://www.dropbox.com/s/ljlgtti4o3e7ea1/2.jpg?dl=0 https://www.dropbox.com/s/xgz0ah0x4gauyqi/1.jpg?dl=0 Continental Winter Contact TS830P mounted on BMW Style 640M rims. Front-255/40/18 Rear-255/40/18 |
10-06-2017, 08:41 AM | #21 |
102
Rep 155
EAS is offering a square set up on apex ec7's in 18x9 with blizzak 255's. comes with tps ready to run at $2400. I'm thinking of going that route in the anthracite finish.
Edit: I placed my order yesterday as they are in stock. It's $2400 shipped. Will follow up once I have them in hand. |
10-07-2017, 05:55 PM | #22 | |
132
Rep 727
I sold my M4 with Comp Pkg. this past July. Living in similar area to you, my M4 would be put in storage by mid-November. As you already know, traction greatly decreases at and below 45F. To be honest, I found a noticeable reduction in traction below 50F. I now have a 2018 Audi S4 with the factory 19" wheels and summer rated tires. I just ordered a winter setup with the Michelin PA4s. Do not drive your M3 with the summer tires once the temps are regularly below 45F. |
