F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 2013 F30 320D ED + BimmerCode
ARMA SPEED
      08-22-2017, 06:57 AM   #1
BimmerStrutt
BimmerStrutt's Avatar
14
Drives: 2014 F21 125d M Sport
I know there is a large thread in the main forum but i want to see how people over here in the UK got on with the app and Vgate iCar 2 adapter
Also i have a F30 2013 320D ED has anyone made changes/coded to one of these as i want to see what the main changes can be made before i buy the adapter required as id hate to have little changes to make after buying
Appreciated in advance guys
      08-22-2017, 09:51 AM   #2
t5pilot
t5pilot's Avatar
978
Drives: M4 CP & S1000 XR
I've just gone down this route. It makes coding a doddle. You can do just about anything in all F & G series models.
Once connected, the app reads all relevant modules & lists what can be changed. Select what you want, click on "code" button & move on to the next. It really is that easy.
/// BM3 + M-Power ///
      09-01-2017, 01:33 PM   #3
BimmerStrutt
14
OK soooo i now have my Vgate iCar 2 WiFi adaptor, i downloaded the app and sat in my car ignition running plugged in and connected
ECU read and not the biggest list of options but a few i wanted so not all bad
I tunr from NOT ACTIVE to ACTIVE and press CODE i then get met with in-app purchases spinning indicator and nothing?
is the £24.99 a must purchase before you can change anything? From what i read it seemed like it wasn't unless you wanted to code loads of cars?
Also when i do get this working and done i must be able to remove the adaptor once ive pressed disconnect?
Little stumped
      09-05-2017, 04:27 PM   #4
t5pilot
t5pilot's Avatar
978
Little stumped
Yes, you have to pay for app in order to code. And I believe until bought, the reading of modules etc. may just be in demo mode. And yes, when you're done just pull the adapter out.
      09-05-2017, 05:30 PM   #5
Flyboy777
76
Drives: 2015 F31 320D LCI
How does this compare to the Carly app & adaptor?
      09-06-2017, 03:38 AM   #6
BimmerStrutt
14
Cool kinda thought as much after trying a few times, will get the app purchased and get some coding done
Thanks for the confirmation, must admit the Vgate Icar 2 adapter is a cool bit of kit, for some reason i thought it would be bigger than it is but ist very small and compact
      09-06-2017, 03:40 AM   #7
t5pilot
t5pilot's Avatar
978
Yep, enjoy
f30post
