08-21-2017, 08:34 AM | #1 |
2828
Rep 3,703
Rear Alignment
Hey guys.
The focus is always on the front, and it seems folks are gravitating to -2.75 with 0 toe after some testing on the track. Just curious where you all are ending up with your rear alignment? I've gone as far as -2.2, but it seemed too much based on treadwear and loose rear traction coming off the corner. I've gone back to -2.0 and it helped, but I still wonder if less would be better. Also, I've stayed consistent with 0.3" toe in the rear based on my shop's recommendation, but no one seems to have a good idea what rear toe should be. Obviously the tires you run will have an impact on this (RE-71R and R888R for me), but what have been you all's experiences? Thanks. Last edited by ZM2; 08-21-2017 at 09:07 AM.. |
01-25-2018, 05:43 PM | #3 |
323
Rep 487
Drives: M2CS
I always run toe in on the rears.
As you pick up speed and up to speed, the toe in will start toeing out. Even at speed you want a little toe in. |
