Thoughts on this alternative to walnut blasting?
08-19-2017, 05:31 PM | #1 |
30
Rep 79
I'm not sure how links work here so i'll post the link as well as the title to the video.
N54 Carbon removal DIY! | Soak and Scrub method | Better than walnut blasting? The guy in the video uses brake cleaner..any thoughts? |
08-19-2017, 07:21 PM | #2 |
22
Rep 100
not better. i did soak and scrub. next time i will walnit blast. just quicker and cleana way veyyer.
08-20-2017, 11:30 AM | #3 |
1905
Rep 6,968
I have done both methods. Walnut blasting is the way to go. No question.
08-20-2017, 07:00 PM | #4 |
Curmudgeon and Pedant
690
Rep 3,489
Considering that the CBU cleaning method for the diesels (335d, x5d, 328d, etc) have two parts to it, I very much doubt the efficacy of this method.
part 1 requires removing the intake manifold and sending it out for soaking in a hot tank (cleaner). Soaking is going to remove much more CBU than a transient spray of brake cleaner (although the cleaning fluids are probably similar.) part 2 - and this is why the brake cleaner method is poor - is to use the CBU walnut wands to clean the ports. A transient brake cleaner spray is not going to do as good as walnut blasting. |
08-26-2017, 02:50 PM | #5 |
40
Rep 97
Drives: 2009 335i
I did walnut blasting and finished up with brakleen. Blasting took 90% of the crud off quite easily.
FBO, Vargas Stg 1, lots of cooling and proper maintenance.
08-27-2017, 01:58 AM | #6 |
E39
134
Rep 286
I've done over 25 Walnut blasts and it's 100% more efficient and easier than this soak and scrub method. I can get the valves almost spotless. Would never waste my time with this
08-27-2017, 08:53 AM | #7 |
53
Rep 151
Walnut blasting is the quickest and most efficient way to clean the valves. First round removes 90% of the carbon, hit them with brakeclean and a gun cleaning brush to loosen the really stuck on gunk followed by a second blast and the valves look brand new.
I've done all three of our bimmers, and got the entire job down to 2 hours. |
