BMW M5 F90 (2018+) General Forums F90 M5 General Forum    2018 BMW M5 F90 Official Thread: Information, Specs, Wallpapers and Videos Galore
      08-19-2017, 12:57 PM   #1
BIMMERPOST / Official Coverage
BMW M5F90
Engine / Exhaust
  • 0-60 mph in 3.2 seconds
  • 0-124 mph in 11.1 seconds
  • 4.4-liter V8 engine with M TwinPower Turbo technology
  • 600 hp from 5,700 to 6,600 rpm
  • 553 lb-ft peak torque from 1,800 to 5,700 rpm
  • M Driver's Package hits 189 mph (155 mph standard)
  • Efficient, Sport and Sport Plus settings
  • Twin-scroll turbochargers with 24.46 psi boost
  • Maximum injetion pressure of 350 bar (up from 200 bar)
  • Oil pan with a small front sump and new indirect charge air cooling units which are 20% smaller than predecessor yet more effective.
  • Oil supply system uses fully variable, map-controlled pump
  • Optimized cross-bank exhaust manifolds
  • Exhaust reduced 11 lbs (by way of fitting a Helmholtz resonator)
  • Flap-controlled exhaust system controlled by selected driving mode
  • New M Sound Control button allows independent control of exhaust flaps
Transmission / M xDrive all-wheel-drive
  • Front wheels only deliver power when rear wheels are not able to transmit any more torque to the road and additional tractive force is required.
  • Active M Differential
  • 3 DSC Modes: 4WD, 4WD Sport, 2WD
  • 4WD gives maximum traction while still allowing some slip at rear wheels
  • 4WD Sport sends more torque to the rear and rear wheel slip is increased allowing for more oversteer and slip angle
  • 2WD = pure rear-wheel-drive mode
  • 8-speed M Steptronic transmission
  • Torque converter lock-up clutch fully engages, proving instantaneous response
  • Shift mapping controlled with Drivelogic rocker switch
  • In manual mode, no automatic upshifts at rev limiter
Chassis / Suspension
  • M-specific Variable Damper Control (Comfort, Sport, Sport Plus modes)
  • M Servotronic steering (incl. three driving modes: Comfort, Sport and Sport Plus)
  • Chassis tuned to achieve neutral steering behavior with linear build-up of transverse loads across the full range of lateral acceleration
  • M-specific double-wishbone suspension front axle with increased track width (64.02 in. versus 63 in. on standard 5 Series)
  • M-specific five-link rear suspension
  • Firmer anti-roll bars and new toe links with stiffer rubber mounts
  • M5-specific elastomer bearings on rear axle mounts
  • Steel X-brace and an aluminum transverse strut at rear axle
  • Aluminum tower-to-bulkhead and tower-to-frontend strut braces
Wheels / Tires / Brakes
  • 275/40R 19 front and 285/40 R 19 rear tires are specially homologated for the new M5
  • Standard 19-inch five-double-spoke cast light-alloy wheels in polished Orbit Grey (front: 9.5x10, rear: 10.5x19)
  • Optional 20-inch seven-double-spoke wheels in black or polished black (front tires: 275/35 R 20, rear tires: 285/35 R 20)
  • Standard M compound brakes are significantly lighter than conventional cast iron units
  • 15.55 x 1.41 in. perforated, inner-vented 6-piston fixed calipers
  • 14.96 x 1.10 [in] perforated, inner-vented single-piston floating calipers
  • Optional M carbon ceramic brakes with front 6-piston fixed calipers (15.74 x 1.49 in.) and rear single-piston floating calipers (14.96 x 1.10 in.)
  • Ceramic brakes reduces unsprung weight by 50.7 lbs
Exterior
  • Carbon fiber-reinforced plastic (CFRP) roof
  • Aluminum hood
  • Rear diffuser, side skirts, the M rear apron, M exterior mirrors and M rear spoiler
  • Hexagonal central front air intake (incorporate oil cooler)
Interior / Technology
  • Red starter button
  • Two red-painted M1 and M2 buttons next to gearshift paddles
  • M1/M2 buttons configurable to control M xDrive, DSC, engine, transmission, damper, steering and M view in HUD
  • Extended merino leather standard
  • Race style bucket M multifunction seats with illuminated M5 logo
  • Aluminum trim with carbon-structure
  • Standard with all driver assistance systems featured in standard 5 Series
Limited BMW M5 First Edition
  • "First Edition" special-edition model
  • Limited to 400 examples worldwide (50 for the U.S.)
  • Available starting Spring 2018
  • Frozen Dark Red Metallic paintwork
  • Individual high-gloss Shadow Line trim
  • Kidney grille, M gills and four tail pipes come in high-gloss black
  • M Sports Exhaust System
  • 20-inch seven-double-spoke light-alloy wheels in black
  • Piano Finish Black interior trims
  • Plaque on center console indicating the car's production number ("M5 First Edition 1/400")
  • Available with full-leather upholstery in Smoke White with red contrast stitching
Wallpapers
2018 BMW M5 (F90) First Edition
2018 BMW M5 (F90)
Videos
Tech Specs
Name:  Screen Shot 2017-08-20 at 11.44.27 PM.jpg
Name:  Screen Shot 2017-08-20 at 11.44.38 PM.jpg
Name:  Screen Shot 2017-08-20 at 11.44.46 PM.jpg
Name:  Screen Shot 2017-08-20 at 11.44.58 PM.jpg
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
Appreciate 2
drexplode1784.50
      08-21-2017, 12:07 PM   #2
sdshah
849
Drives: F85 | Panamera GTS
3.2 seconds. Holy shit.
Appreciate 8
YungDro1089.00
F831355.50
flanast148.50
mashimarho2107.50
Simple1133.50
jhbodle144.50
      08-21-2017, 12:08 PM   #3
deemo319
deemo319's Avatar
1751
Drives: BMW
I think this has serious potential to lead in a very strong segment as BMW intends it to.
F831355.50
      08-21-2017, 12:12 PM   #4
Phatcat
751
Drives: BMW M5, X5M
Never had any doubt about it after seeing both the new Porsche Panamera and E63 S came in even heavier than the previous generation, both over 2000 Kg.
They are going after a different sort of buyers.
The official weight is listed at 1930 Kg, F10 is 1945 Kg, that's pretty impressive considering they have now added a AWD system.
F831355.50
      08-21-2017, 12:12 PM   #5
Jez_zza
Jez_zza's Avatar
Spain
439
Drives: M5 F90
Oh boy !!! That's fast ... real real fast .. want
      08-21-2017, 12:12 PM   #6
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
I understand the blasphemy as much as the next guy but damn... performance hard to argue against
she’s home! '22 M4 Comp xDrive
Appreciate 2
F831355.50
KevinM2935.50
      08-21-2017, 12:13 PM   #7
stefan
stefan's Avatar
No_Country
2354
Drives: M2 Comp
AWD and an 8sp auto. More about numbers than fun.
///M Power
mundo7465.00
      08-21-2017, 12:14 PM   #8
ASAP
ASAP's Avatar
10159
Drives: '23 X3 M40i
I like it as a whole but the interior to me is just an utter mish mash of a lot of things... the m buttons and that shifter just seem off... auto tranny doesnt help either.... we'll have to see how it drives.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
JTO245274.50
      08-21-2017, 12:15 PM   #9
Law
Global Moderator
Law's Avatar
6381
Drives: E90 M3 6MT
2011.5 BMW M3  [10.00]
2004 BMW M3  [10.00]
While the overall shape and profile is very similar to the F10, this is still a very good looking car.
The F10 was a handsome machine anyway, so any evolutionary similarities in appearance aren't necessarily bad.
I may be in the minority, but I think the front looks badass.
If anything, it's the rear that's a tad awkward.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread
Appreciate 2
F831355.50
      08-21-2017, 12:19 PM   #10
Jason
Administrator
Jason's Avatar
40848
Drives: F80 M3
Videos are live!
      08-21-2017, 12:20 PM   #11
bmbweber
236
Drives: 2014 435i M-Sport
Would've liked to see some aggressive fenders like the F80...
      08-21-2017, 12:24 PM   #12
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
Yasss, BMW got this one right!
F831355.50
      08-21-2017, 12:28 PM   #13
Ffs630
Drives: 2008 335xi sapphire black
Too big!
      08-21-2017, 12:29 PM   #14
X6DB
43
Drives: 2024 M4 Comp xDrive
Looks great!
      08-21-2017, 12:31 PM   #15
vicslick146
Drives: 2016 BMW M5
Is it me or does each generation of M5 seem like we're getting less and less value, to the point where the F90 feels like a ripoff..? The M5 used to be... I dunno, special? We used to get bespoke engines and transmissions and suspensions... The E39 engine had 8 individual throttle bodies... The E60 was a freegin V-10 that revved to 8500 rpm! With the F-10, was disappointed the engine was largely sourced from the stock engine, but at least it had a high performance DCT tranny.... With the new M5, what the heck is the M-premium going towards exactly...? The profit margins for the F-90 must be through the roof.... Don't get me wrong, I'm sure the new car will be quick for sure, and I'm fully aware of that the sole purpose of any business is to make money, period. But as a long time m enthusiast and current F-10 driver, it's just a little sad I guess.....
Appreciate 4
      08-21-2017, 12:34 PM   #16
Crashnbrn5
507
Drives: 2016 335i GT M-Sport
wowsers, SIGN me UP
      08-21-2017, 12:35 PM   #17
bimmer_335
177
Drives: 540 mSport
love the lines on the hood... why couldn't they put that hood on all G30s!!!!
      08-21-2017, 12:36 PM   #18
deemo319
deemo319's Avatar
1751
Drives: BMW
I think the competition within the luxury performance segment is excellent.
Previous and current performance sedans are typically laden with safety features, technology and all-wheel drive systems are not lightweights, and you as well other here know these types of cars transition from generation to generation with more of these attributes with increased weight as an underlying detriment.
Whatever weight that has been removed from the F90 M5 is a plus. The new Panamera looks refreshing in the metal since it's launch and Mercedes-AMG continues its push but without much emotion to its car. Although typical Mercedes-Benz, but they own the sound department.
It's the hideous Audi RS7 with its exotic car straight line acceleration, road holding and wet weather abilities that that I have to begrudgingly say leads this particular segment. With BMW M coming after them now, hard.
      08-21-2017, 12:38 PM   #19
somer
966
Drives: F10 M5 CP
Duno if anyone else noticed, but fuel tank capacity is down to 17.9 gallons (68L) vs 21.92 gallons (83L) in the F10. Stupid.
Kyngofpop676.00
      08-21-2017, 12:43 PM   #20
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
2897
Drives: 2018 Audi S5 Coupe
Pulling a Mercedes with the 'First Edition' nonsense. Will wait to see it.
The shift lights in the heads-up display is nice.
      08-21-2017, 12:43 PM   #21
infamousq
infamousq's Avatar
311
Drives: 2018 Ford Raptor
600 Hp are you kidding me....
2021 M5 (COMING SOON)
2015 M5 Imola Red (sold)
2008 Monaco Blue (sold)
2002 M5 Carbon Black (sold) should have never sold her
      08-21-2017, 12:44 PM   #22
Jez_zza
Jez_zza's Avatar
Spain
439
Drives: M5 F90
let's hope it's a typo !
m5post
