08-17-2017, 03:14 PM | #1 |
140
Rep 625
FRIED DME??
So I've been having issues with low end power (non existent very slow lifts from stop)
P112E code.... (throttle angle too low) I had an Indy hook it up to a computer scanner and said I had a whole bunch of DME codes and that my DME is fried..... That's the only issue I have.... How screwed am I or is the Indy scamming me |
08-17-2017, 04:15 PM | #3 |
364
Rep 775
Bad battery???
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
08-17-2017, 04:40 PM | #4 |
140
Rep 625
The battery codes were from something else lol
The main thing is that the issue I have is very inconsistent and intermittent I did a leak test and there are no leaks at all within the intake tract!! This leads to sensor / dme issues.... I've replaced MAP sensor no luck... I have a new MAF... Should I replace the TMAP |
08-17-2017, 06:12 PM | #5 |
BimmerPost Supporting Vendor
24298
Rep 190,975
Take it to another Indy and see what they say
08-18-2017, 01:47 AM | #6 | |
568
Rep 1,292
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
RoundelM31838.00 |
08-18-2017, 06:57 AM | #7 |
1838
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
If you haven't replaced your battery yet, do so. I've never had one that lasted more than 4 years, so yours may already have a dead cell. If you're not getting proper voltage and it's throwing codes, a simple battery test will go a long way towards diagnosis. If your DME was truly "fried", the engine wouldn't start. In that case, the proper term is "bricked".
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-18-2017, 04:15 PM | #8 |
207
Rep 488
Use ISTA to check the codes, but only after you clear them first. Check which ones come back.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
08-18-2017, 05:46 PM | #9 |
140
Rep 625
08-18-2017, 09:06 PM | #10 |
207
Rep 488
Quick? Not even close. Post in this thread asking for details and you should get links to guides and such: http://f30.bimmerpost.com/forums/sho....php?t=1312102
eluded3058.00 |
08-19-2017, 07:25 AM | #11 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
youll know when you brick your DME. let me tell you..
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
08-19-2017, 09:07 AM | #12 |
1084
Rep 2,361
I wouldn't worry about all those codes. I tried a "full/deep scan" at my shop also and got a HUGE list even though there was only CEL for one error. Cleared them all - no issues since.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
afranke207.00 |
08-19-2017, 09:57 AM | #13 |
140
Rep 625
People said that if the DME goes bad my car won't start??
So this all happend after fried tmap due to Jb4 install.... I've been talking to a guy in bmw service and he said it maybe because of the ground point Said to move it to the oil filter housing.... I'm using thick gauge speakerwire for the ground point.... no issues there right??? Code is back after clearing and same issue with new map maf and tmap sensor :/ |
08-19-2017, 03:24 PM | #14 |
207
Rep 488
The MAF code is common on aftermarket intakes. A lot of us run with the MAF unplugged and just deal with the code/light. The other one, if you think the ground trace is fried, you just need to tap the ground wire of the TMAP and run it to any ground (last page of the install guide: http://www.burgertuning.com/instruct...4_f_series.pdf). I assume speaker wire should be OK, but I always use just regular like 18 gauge (I think).
08-19-2017, 03:26 PM | #15 | |
140
Rep 625
Ground is okay I reworked it wth new wire |
08-20-2017, 12:37 AM | #16 |
1084
Rep 2,361
Hi
I fried the TMAP trace on my DME my letting the USB cable come in contact with V+. I wrote this guide - hope it helps. http://www.n54tech.com/forums/showthread.php?t=31469
(A Dane in China) |
08-21-2017, 01:17 PM | #17 |
20
Rep 99
Not to hijack the thread but I had a P112F code that I was able to clear and it has yet to come back. This was after I went FBO and had driven the car for about 6 hours of total drive time. Wasn't sure if this had to due with the TMAP.
