08-13-2017, 04:40 PM | #1 |
609
Rep 1,124
Changing M2 springs for daily driver duty?
The OEM suspension seems great for the track but leaves something to be desired on the everyday crap roads in NY. Has anyone toyed with the idea of changing out the springs for daily driver duty?
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
08-22-2017, 11:26 AM | #2 |
BimmerPost Supporting Vendor
3815
Rep 54,314
Drives: F80 M3
The springs are fine. The OEM dampers aren't the greatest and don't have the proper damping.
You will find coilovers out there with higher spring rates than OE but still rides better. |
rich8566608.50 |
08-22-2017, 07:13 PM | #3 |
609
Rep 1,124
Thanks - so the solution is to change out the dampers? Any specific thoughts ?
08-22-2017, 08:02 PM | #4 |
3815
Rep 54,314
Drives: F80 M3
08-22-2017, 09:47 PM | #5 |
609
Rep 1,124
I'm feeling incredible harshness and crashing suspension pieces when I drive to work on the interstate when I bounce over ridiculous frost heaves in the pavement
08-22-2017, 11:07 PM | #6 | |
3815
Rep 54,314
Drives: F80 M3
Changing the springs will likely not help unless your springs are binding or you are hitting the bump stops. |
rich8566608.50 |
08-28-2017, 11:30 AM | #8 |
3815
Rep 54,314
Drives: F80 M3
