Coolant light
08-05-2017, 02:56 AM | #6 |
163
Rep 321
I had a small leak near my top radiator outlet where the upper radiator hose goes to. The plastic on that I guess gets brittle over time and can spring a small leak. I replaced the radiator and voilą problem solved.
08-05-2017, 04:14 AM | #7 |
17367
Rep 18,769
Have the system pressure tested if you can't find a leak. Or try running the cold water pump bleed procedure first, it's safer than having the engine running.
09-07-2017, 09:22 AM | #9 |
Rep 103
Have the same issues...coolant light would come on every month or so. Had it pressure tested this morning and both sides of the radiator are leaking. Quoted $703 from my local indy shop. Called BMW and there's no extended warranty or recall...dammit.
09-16-2017, 12:37 PM | #10 |
54
Rep 297
my cpo expires this december, sounds like i better get it back down there!
09-22-2017, 11:15 AM | #11 |
54
Rep 297
mine was leaking from the lower hose inlet on the lower left side, cpo covered replacement, thank the cpo gods!
