E92 335 spacer recommendations
07-29-2017, 02:25 PM | #1 |
Rep 10
I want spacers, like really bad. I just bought new wheels (M359 18x8.5 all around) and upgraded to 255s in the rear. So what width do you guys recommend for stock ride height. I don't want to have any issues with rubbing and don't want to roll my fenders.
07-29-2017, 03:41 PM | #4 |
Is it the shoes!?
3884
Rep 5,112
VRSF. They come with extended bolts too which is really cool. I never had rubbing until I got some new DWS 06's in the rear. They only rubbed a small amount if I had two people in the back and I hit a really big dip.
It ended up resolving itself after about a month. No more rubbing at all. If you use a wheel lock, you can safely put 15mm extended wheel locks on all 4 corners. You might be able to do 15mm up front, but I like the look of 12.5mm. I also have a 255 rear setup, and I wouldn't go any more than 15mm before rolling. Any time I go to a tire shop, I let them know that the front bolts are shorter than the rear. Usually they keep all the bolts with the same wheels, but it never hurts to let them know. They usually appreciate the heads up. |
