07-27-2017, 04:12 PM | #1 |
4016
Rep 3,539
Drives: 328d Wagon, M2 Comp, i4 eD35
Transfer Case Failures Database
I was curious about all the transfer case failures, and the claim of correlation between them and factory staggered tires setup, so I did a quick search through here and another forum for F3x transfer case issues. Thus far I've found 28 instances.
You can see the what I've found in this Google spread sheet. Please feel free to add missing info, or your incident, if not listed. So far, I don't think there's enough conclusive data to link staggered setups to the transfer case failures. Last edited by FaRKle!; 07-27-2017 at 04:30 PM.. |
07-27-2017, 06:05 PM | #2 | |
1044
Rep 2,152
i should get mine checked out before my warranty is up. |
07-27-2017, 07:26 PM | #3 | |
4016
Rep 3,539
Based upon that, I'm wondering if having the transfer case fluid replaced (say at 30k) helps prevent the failure, or if the failure mode isn't related to the fluid at all. |
johnung4528.00 |
07-27-2017, 07:28 PM | #4 | ||
42
Rep 142
08-15-2017, 06:59 PM | #6 |
44
Rep 30
I just got my 3rd transfer case @ 119,xxx miles. Counting the one on it when i bought it new, that's 4 in 120k miles...Each time it completely fails, blows up or whatever and the car is undriveable.
08-16-2017, 10:20 AM | #7 |
597
Rep 1,805
This should be a sticky
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
Pittcrew34.00 |
08-23-2017, 04:50 PM | #8 |
Rep 5
Hello! I recently buyed a 435 i xdrive with mppk. Iove the car but something is boddering me: when in strog acceleration the car seems to hesitate a lots off times and i see the power comming down, in the sport screen, when.this occurs. My bmw.dealler.says is transfer box, he don't have any code error but when he turn ir off the problem stops.. i am wating for.the repair price. It's sad, the car as only 50000km's.
Anyone have an ideia off something else causing the symptoms? Thank you very much!! |
10-10-2017, 11:25 AM | #11 | |
180
Rep 466
10-11-2017, 09:15 AM | #12 |
Rep 1
Have a '13 328ix purchased as a CPO with 37k miles. Hesitation / slip started around 51k and got progressively worse on acceleration. Originally thought it may be a fouled plug or universal joint but no codes ever were thrown. Had the Dealer look at the problem and replaced the transfer case at 53k miles. Good thing it was under warranty (whew). $3k plus repair cost.
10-17-2017, 09:55 PM | #13 |
21
Rep 205
great write up.
my advice to potential buyers is to get an extended warranty if possible. good thing i purchased one when i got the car. the total bill for the repair was $6500 |
05-15-2018, 09:45 AM | #14 |
92
Rep 211
our '15 328d Wagon is going in today for this issue I believe. The foreman went on a test drive with me and thinks either carbon build up or Transfer Case (most likely the latter since there are no drivetrain malfunctions/CELs). They will unplug the transfer case and see if the issue still happens to determine if it's the Transfer Case.
Car is still under warranty fortunately! |
07-01-2018, 12:21 PM | #15 |
1410
Rep 1,803
Honestly, I wonder if this is a software issue.
The front diff is a full time locked differential, with the slip for wheel differential (for turns) happening inside the transfer case. The clutches happen to be very strong inside the transfer case, and if the transfer case actuator is programmed to be aggressive, the extra differential speed may be putting stress on the output flange. I have a close contact at BMW engineering and I will ask him to see what he can find out as well. I find the ATC35L a robust transfer case with good build. Especially when compared with old transfer cases with plastic gears and things. I wonder if running it in 2wd mode (coding or disabling things) is protective to the flange. I am at 79,700 miles, original 27107505374 case built Sept 20th, 2013. My last 9000 miles have been using strictly rear wheel drive only, through disabling the VTG module, and tuned with more power. I was preparing to start my own thread for analysis... but there is no reason, now that I was directed to this thread. This is what I was going to post to try to prove my hypothesis: Use for ideas if nothing else. _________________________________________________ If you have a 4wd BMW with the ATC35L transfer case, I invite you to participate in this data collection. *It is important to have documentation of transfer case failures, as well as data on cars without transfer case failures, for a control group* Data Collection Having very accurate data is critical to sorting out clues as to what may be causing the failures. I ask that you post in the following format, for each transfer case failure event, or if no failure in your F3x, then fill out information about your car. A. Basic Car Info B. Driving Habits/Conditions C. Transfer Case Failure If you have had multiple failures for the same car, please list each separately! Please add any other information that you consider relevant with great detail. If you have had NO transfer case failures on your F3x, please fill this out as well, for data control and comparison. Control data is just as important!
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 07-01-2018 at 12:28 PM.. |
08-06-2018, 02:28 PM | #16 | |
10995
Rep 32,881
https://f30.bimmerpost.com/forums/sh...er+case&page=2 |
08-09-2018, 05:29 PM | #18 |
Rep 5
My 2014 328d x drive wagon's transfer case just crapped out at 81,000 miles. It sputtered a bit but I thought it was an EGR issue or something. Driving in town it just totally failed. Dealer reported the today its a $7000 repair. New 27107649725 Transfer Case Assembly required. Dealer said I abused it. I have been accused of driving like an old lady. I took this very hard as I have done nothing of the sort. Having joined this forum today I have read all the posts and there are lots of these failures contrary to what the dealer told me. Thank you everyone for sharing this information. I have also added myself to the spreadsheet. Now, what do I do? Buy the $5400 part and have BMW install it? Buy an OE part new on eBay and have them install it, (no warranty). Take it to someone else (BMW guy) and have them install it? Please help. I am still paying for the car.
Loudpatriot770.00 |
08-09-2018, 05:50 PM | #19 |
1410
Rep 1,803
The other part number 27108643149 is currently $700 brand new from dealer, discounted in the last few months from $5000. Neither one is clearly better than the other.
It comes with new module, and without the mounting bushing. Breather hose needs to be transferred from yours, and then make sure it has oil.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
08-10-2018, 04:01 PM | #20 | |
1044
Rep 2,152
https://www.getbmwparts.com/oem-part...5l-27108643149 the 7k dealers are charging.. they're pretty much charging 6k for labor? |
08-10-2018, 05:24 PM | #21 |
1410
Rep 1,803
They have 2 choices for transfer case.
https://www.realoem.com/bmw/enUS/sho...diagId=27_0065 27108643149 recently reduced to $700 from $4-5k (likely as a good faith initiative) or 27107649725 not reduced (yet?) You would also need a new mounting bushing, oil, and you should put in new flex disk. No it does not cost $6000 in labor. Alternatively you can replace just the sheared output flange (that's the part that generally fails, for whatever unknown reason) for about $300 plus labor. It may be possible to do on car with driveshaft removed.
08-10-2018, 05:36 PM | #22 | |
1044
Rep 2,152
it's been reduced also. Could this be the beginning of a 2k job at the dealership? |
