Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 235/45/18
      07-17-2017, 12:07 PM   #1
E60525d
E60525d's Avatar
281
Drives: 330d M Sport LCI
Has anyone fitted 235/45/18 all round? Any issues with this setup?
I have found one member here with them and they look OK. They fill the arches nicely. I do have sports suspension so will be 10mm lower.
http://www.e90post.com/forums/bpgara...=view&id=10555
I am aware of a 5% difference on radio so speedo will be out slightly.
Also will 235 be OK on a 8.5j wheel? I am looking for little as stretch as possible.
      07-17-2017, 01:25 PM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
235/35/18 is super small, speedo will be off by about 8%
Do they even make tires in 235/35/18?
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      07-17-2017, 01:36 PM   #3
E60525d
E60525d's Avatar
281
Sorry that was typo, now corrected to 235/45/18.
      07-17-2017, 03:04 PM   #4
ApexWheels
BimmerPost Supporting Vendor
ApexWheels's Avatar
1428
Drives: M3
The correct size would be 235/40-18 for the front, or front and rear as a square fitment.
235/45-18 would be too tall, and there are implications for running tires that are drastically taller then the target height. Rolling diameter plays an important role in how your car performs, functions etc.
For reference and as a benchmark, one of the common OEM 18" configurations has heights of:
Front 225/40-18: 25.09" tall
Rear 255/35-18: 25.03" tall
235 tire options being discussed in comparison to the front OEM tire height:
235/40-18: 25.4" tall (1.24% taller - acceptable)
235/45-18: 26.33" tall (4.71% taller - unacceptable)
- Ryan
Appreciate 2
      07-17-2017, 03:17 PM   #5
E60525d
E60525d's Avatar
281
Thanks for the reply. I agree that preferably I would like to keep within 3% of OEM. But will an extra 1.5% be much different?
Is the main issue the speedo?
My main aim for doing this is to improve ride comfort a little. Filling the arches better is a nice bonus!
      07-17-2017, 03:29 PM   #6
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Most people would probably go 235/40/18, unless you live in a area that the roads are filled with pot holes, then it would make sense to have a little more meat, in order to help save a rim or two.
      07-17-2017, 03:36 PM   #7
ApexWheels
ApexWheels's Avatar
1428
Drives: M3
In short, yes. 4.71% taller then the OEM targeted height is no bueno. Fitment in relation to the fender liners, electronics that control the driving experience (speedo, traction/stability control etc) and performance (gearing and handling characteristics) is negatively impacted. If you are looking for a touch more height while staying within the "allowable range", go with 245/40-18.
Note the 235/40-18 is already taller than the OEM 225/40-18, so you are getting more sidewall.
If you still have wheel gap with the 235/40 or 245/40 tire, the best approach to eliminating it is to lower the car - not compromise the tires by going with a overly tall aspect ratio.
- Ryan
      07-17-2017, 03:48 PM   #8
E60525d
E60525d's Avatar
281
Yes we have terrible roads in the UK, so every little improvement helps.
- Ryan
Think your right, I will try to stay within the 3%.
So my wheels are BMW Style 193. So 18x8 and 18x8.5.
OEM tyres are;
F: 225/40
R: 255/35
So my options are;
F: 225/45
R: 245/40
Other option is 225/45 all round. But sort of thinking against it as it would look stretched on the 8.5 wheel.
      07-17-2017, 08:31 PM   #9
mweisdorfer
1903
2008 bmw x5  [0.00]
I'd go:
235/40/18 - front
255/40/18 - rear
      07-17-2017, 09:06 PM   #10
FCobra94
Guest
n/a
Drives:
This.
You could probably even go 255/40/18, depending on the tire.
Or 255/35/18 as well...play with the numbers and see what you think will work best in your situation.
      07-18-2017, 02:10 AM   #11
E60525d
E60525d's Avatar
281
I'd go:
235/40/18 - front
255/40/18 - rear
Not too sure as they seem mis-matched compared to what I have now.
There is very little difference in the front compared to OEM but yet a 4% difference in the rear.
      07-18-2017, 02:15 AM   #12
E60525d
E60525d's Avatar
281
Originally Posted by FCobra94 View Post
This.
Yes on the rear, 245/40/18 looks like a good fit. I am getting a good increase in sidewall and yet within the 3% difference. Plus it will go nicely on the 8.5 wheel.
Front's I am am still debating. 215/45 likes a good fit. I will play with the numbers and see whats best.
      07-18-2017, 12:38 PM   #13
ericlol
BMW Amature
Drives: 2011 AW 335i xDrive
2011 BMW 335i  [0.00]
how bout 235/45 R17, does it fit on E90 335xi? i searched wheel-size.com, it doesn't say that it will fit
      07-18-2017, 12:47 PM   #14
Antetokounmpo
1552
yes that's the same od as 235/40/18 which easily fits. it's like 1.2% larger than stock sizes.
      10-20-2017, 09:57 PM   #15
CanadianTSi
CanadianTSi's Avatar
207
Drives: 2014 535 xDrive Diesel
Just thought I would add to this incase anyone is searching in the future. This is my wintet setup. I wanted more sidewall and a taller tire coming from the 225/40/18 I was running.
235/45/18 all around on the OEM Msport rims, fills up the wheel well perfectly.
Appreciate 2
gxe2se37.50
      11-10-2018, 02:54 AM   #16
E60525d
E60525d's Avatar
281
Thanks, looks really good. Did the rear tyre go on the rear wheel ok, not too stretched?
      11-23-2018, 02:31 PM   #17
johnmyster
111
Drives: 2011 e92 n52
2011 (LCI) e92 with sport package...
I had the style 189 staggered wheels. 18x8 front, 18x8.5 rear. Ran 255/40r18 rear and 235/40r18 fronts. (Not x-drive.)
Now, got an extra set of front rims so 18x8 all around with 245/40r18 Michelin AS 3+ No rubbing. Can run spacers in the rear if desired. I had 10mm, and could probably do 15mm.
      11-23-2018, 03:16 PM   #18
FCobra94
Guest
n/a
Drives:
Pics?
      11-24-2018, 02:00 PM   #19
johnmyster
111
Pics?
I mean, it looks stock except the tires have more sidewall, and are "fuller" on the wheels and wheel wells. I didn't do it for the look, but to be square (for rotations) and have more sidewall. Just verifying that this particular combo doesn't rub.
My car is sitting a bit high in the front anyhow because of brand new upper strut mounts. I'm hoping they'll settle in soon.
      11-24-2018, 03:09 PM   #20
FCobra94
Guest
n/a
Drives:
Pics?
Word...was hoping to see those exact tires in 245 on an 8" rim.
      11-27-2018, 09:40 PM   #21
scrammer
scrammer's Avatar
422
Drives: 2017 M3 Ultimate
When I had my 335is I ran a square setup 18 x 8.5 et35 BBS CH with a 15 mm H&R spacer in the back w/ 235/40/18 all around.
The car's handling was incredibly neutral on turn-in and you could still do a little work with the throttle on corner exit ... Fun!
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      12-02-2018, 01:27 PM   #22
E60525d
E60525d's Avatar
281
CanadianTSi Does your 335i have sport suspension or standard?
