2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Second cigarette lighter port?
      07-13-2017, 08:15 PM   #1
Powaup
Powaup's Avatar
1253
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
Exclamation Second cigarette lighter port?
Is there a second cigarette lighter outlet power outlet in the 2 series besides the one near the cup holders? In the M4 (and maybe all F3x) there is an outlet under the glove box in the passenger footwell area.
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      07-13-2017, 08:25 PM   #2
sausagemcmuffin
Drives: 2017 230i 6MT
There's one on the back of the center console for backseat passengers
      07-13-2017, 11:12 PM   #3
Powaup
Powaup's Avatar
1253
2015 BMW M4  [10.00]
Oh awesome! That might be able to work. I am looking to install a dash cam but my radar detector is already taking up the front power outlet
Instagram: @ Powaup
      07-13-2017, 11:32 PM   #4
overcoil
3074
Drives: M235i 6spd
Had you though about hardwiring into the fuse box ? You don't need to splice into existing car wiring but buy a fuse holder that has a wire attached that uses existing fuse box location plus a power cord for the device that crimps to the fuse box wire ?
Had you noticed how easy it is to run wiring from near the rear view mirror into the headliner edges down the A-pillar and either to the window base across top of dash or under door weather stripping under dash ?
BTW a third power outlet in the trunk.
      07-14-2017, 06:39 AM   #5
BEM-S4
BEM-S4's Avatar
4516
Drives: Dinan M235, Dinan Sport Wagon
The path of least resistance is to mirror tap the radar detector then use either outlet for dashcam or usb in glovebox.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      07-14-2017, 08:13 AM   #6
jmwilson125
341
Drives: 2016 M235i
Just hard wired mine yesterday. It's super easy and doesn't take up a cigarette lighter. Also it can be always on to record when parked. Definitely the way to do it.
      07-14-2017, 11:34 AM   #7
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
I didnt want to hard wire.
I purchased this 2x cig 2x usb and mounted in the glove box. The only wire you see is the one that comes out of the corner of the glove box and plugs into the cig lighter by the cup holders.
The radar detector and dash cam wires are neatly tucked under the headliner and behind the passenger pillar. It gives you 2 usb ports for phones or other things as well.
Its also just 1 quick plug to unplug or plug in.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      07-20-2017, 01:02 PM   #8
Powaup
Powaup's Avatar
1253
2015 BMW M4  [10.00]
Any DIYs out there for the fuse box hard wire?
Instagram: @ Powaup
      07-20-2017, 01:04 PM   #9
Powaup
Powaup's Avatar
1253
2015 BMW M4  [10.00]
Did you mirror tap yourself, if so was it hard? and do I need a blendmount if I'm gonna mirror tap? last I checked those things were pricey
Instagram: @ Powaup
      07-20-2017, 01:05 PM   #10
Powaup
Powaup's Avatar
1253
2015 BMW M4  [10.00]
Oh sweet good to know, did you buy that thing off amazon? and do you happen to have any pics of your setup?
Thanks for the advice
Instagram: @ Powaup
      07-20-2017, 01:06 PM   #11
bryan_G01
bryan_G01's Avatar
1165
yes amazon. ill get pics when im in the car next. Not really much to show.
www.nybmwcca.org
Current Cars:
      07-20-2017, 01:13 PM   #12
BEM-S4
BEM-S4's Avatar
4516
You do not need a blend mount at all the two things are completely unrelated. The mirror tap is literally 30 seconds of work, 2 minutes if you have a convertible. You pull the cover apart, shove the taps in, tuck the wire away and you are done.
The blend mount does nothing beyond what it's name would imply, it mounts the detector aka hangs it where it is going to live. You can use a blend mount, whatever came with your particular detector, or another option that I would HIGHLY recommend is one of these:
http://www.ebay.com/itm/1-x-Permanen...72.m2749.l2649
Just make sure you get the right one for your detector. Cheap, durable, and low profile.
2022 Macan S
      07-20-2017, 03:07 PM   #13
overcoil
3074
Drives: M235i 6spd
Read this and review the video enclosed with it.
http://www.vortexradar.com/2016/07/h...adar-detector/
Then go to YouTube and search for BMW dash-cam hardwire.
The VortexRadar link above should really clue you in.
someone told me to use Mil Spec connectors, chk this out
https://milspecwiring.com/store/inde...egory&path=141
      07-20-2017, 10:53 PM   #14
kohlzor
47
Drives: 2017 M240xi
They don't make wires for dash cams that plug into mirror do they?
Powaup1253.00
      07-24-2017, 03:44 AM   #15
Troppo
Keyboard warrior
Troppo's Avatar
16
Drives: X3.
There is another one on the RH side of the glovebox, underneath. On Aussie cars, anyway....
      12-11-2019, 07:01 PM   #16
cooolone2
cooolone2's Avatar
625
Drives: 20' M240iX B58, 01' 330XI E46
Reviving this ghost thread because I had the same question, lol.
Found that on M240, as noted above, on the bottom of the glove compartment, left side footwell, there is a hole there seemingly for a 12V outlet, but it's empty.
Has anyone installed a 12V outlet there? Fuse-block tap or otherwise? I may just do that, but figured to ask if anyone has gone before
Tags
cigarette lighter, power, secret power
2addicts
