BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > How to update CIC without ICOM
      07-10-2017, 04:37 PM   #1
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
Credit to anees for this ...
If you have an LCI, then your car should be wired for ethernet already. Otherwise, connect the CIC to the OBD. See the attached pic ( not mine ). 8, 12, 13 and 11 are pins on the OBD socket.
You will need an RJ45 ethernet to OBD cable.
Make sure your EDIABAS.INI settings are for ethernet ( ENET ) and that you IP settings on the laptop are set to automatic. In this case, your pc will get its IP number from the CIC unit.
In WINKFP, make sure you choose ethernet as the interface, and you would flash the CIC in the following order:
63
62
A0
Note, when 63 finishes, DO NOT exit WINKFP, but just process the next module 62, and so on for A0. Only when A0 is finished, then you can exit WINKFP.
If you exit WINKFP after even a successfull flash of 63, there is a chance of bricking the CIC. Then you would probably need an ICOM to get it out of bootloader mode.
And make sure you use a proper power supply...not battery charger !
When you doppelkaplung you doppel your fun.
6ixSpd6015.50
      07-13-2017, 12:09 AM   #2
FaxData
98
Drives: 2017 330e (F30)
I assume you mean this post? Have you tried this? I couldn't make heads or tails of the diagram... Thanks!
      07-13-2017, 05:02 AM   #3
Aus335iguy
Aus335iguy's Avatar
Australia
650
That's the one. I moved it out so it's in its own thread and I think I get the diagram. Has anyone that's tried this succeeded though ?
      07-13-2017, 02:16 PM   #4
opjose
opjose's Avatar
242
Drives: 335xi
This cable hooks up Ethernet via OBD
https://www.amazon.com/Interface-Cab.../dp/B00BFRW6FO
      07-22-2017, 04:38 PM   #5
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Thanks! What are the benefits of updating the firmware?
      10-14-2017, 07:36 PM   #6
smallseafishie
110
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
Has anyone ever accomplished this? I tried it but couldn't get it to work.
Auto Negotiations for DHCP never completed. I only got the default windows private IP. If I manually set it to 169.254.199.98 and ping 169.254.199.99 (CIC) I get a response from the CIC.
I used comfort mode and select 6I63 module. I get a error 106 though. Any pointers?
      10-15-2017, 12:12 AM   #7
Ghannes
Drives: e91
I'm also wondering why? Any new features or something?
      10-15-2017, 03:06 AM   #8
Aus335iguy
Aus335iguy's Avatar
Australia
650
For those looking to get apps/connected drive there are versions of software that have it and those that don?t. Their was a need at one time to get a particular version also because it didn?t need activation codes as well but that?s apparently a thing of the past
      10-15-2017, 09:43 PM   #9
smallseafishie
110
Yes CIC software has been "jailbroken" in a sense that all FSC codes are accepted via an exploit that intel123 developed. The exploit requires the newest software revision C1A. The exploit "virginizes" the CIC and will accept partially signed (FSC) certificates for BMW apps, nav, voice control, etc.
      10-15-2017, 10:39 PM   #10
Aus335iguy
Aus335iguy's Avatar
Australia
650
SOunds like you know more about than me !!! I gave up at the point youre now starting out at which was i need to update my CIC .
If a more comprehensive guide existed and i knew it would work on Australian CIC id have a go
      10-16-2017, 01:54 AM   #11
anees
anees's Avatar
61
Drives: E90 330i Sport
You can update your CIC via a direct ethernet connection, however, you will need to use Tool32 to set the CIC into bootloader mode. When the CIC restarts, you run the risk of losing connection with it, therefore, a chance of bricking it.
An easier and probably cheaper way is to get a ZGW module, connect it to the CIC ethernet connections, and then connect the ZGW to your pc / laptop ethernet port.
You can then flash the CIC.
You will need to get a ZGW with MOST connections and ethernet capability.
      10-16-2017, 02:15 AM   #12
Aus335iguy
Aus335iguy's Avatar
Australia
650
Whats a ZGW?
      10-16-2017, 02:49 AM   #13
anees
anees's Avatar
61
Zentrale GateWay.
Used to send Power Line, CAN messages, etc.. to the CIC. It is normally found in a 5-series, however, it can work for the E90.
In the F-30 series, the Front Electronics Module ( FEM ) is a combination of the CAS / ZGW modules.
And no, you cannot install an FEM from the F30 into an E90. Therefore, the ZGW will have to do
Whats a ZGW?
      10-16-2017, 02:33 PM   #14
PichaDis11
PichaDis11's Avatar
295
Drives: E90 N52
Would this flash give the opportunity to enable BMW Live for US CIC?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      10-16-2017, 03:31 PM   #15
Aus335iguy
Aus335iguy's Avatar
Australia
650
I think so - IVe managed to get it working here in australia(tethered to my phone) its not very useful though in my opinion. the apps is the most useful as you can use it to control music streaming playlists etc. I didn’t use this method above though
      10-21-2017, 01:35 PM   #16
smallseafishie
110
ZGW still requires to another module. If I'm going to buy another module, I might as well get a ICOM-B clone.
Anyways... I have spare CIC that I got for cheap at a junkyard so I'm going go out on a limb and do what everyone recommends against and try to do the update with a OBDII cable. If it fails, I'll just stick my original CIC back in.
63 just started flashing so I'll report back with results...
      10-22-2017, 09:40 PM   #17
Terraphantm
253
Drives: E46 M3 Coupe
Are you using Bimmergeeks' pro cable by any chance? That should be able to do it (though they understandably don't won't to guarantee that). Otherwise you're likely to run into the D-CAN bug.
      10-26-2017, 03:04 PM   #18
riso1988
36
Drives: '18 440i xDrive GC, '06 330xi
Any updates? Looking to update as well
      11-01-2017, 03:11 PM   #19
smallseafishie
110
Well I can tell you that 63 alone was going on for 14 hours (~70%). My wife plugged in a vacuum cleaner and it tripped the breaker for my power supply to the car so that rendered my cic unit dead... Sucks that I didn't get to actually see if this works... Will try again this weekend as I got another CIC for cheap on ebay.
      11-29-2017, 10:11 AM   #20
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Any updates on this? Has anyone actually gotten the update to work over Ethernet?
thank
      12-02-2017, 03:44 PM   #21
anees
anees's Avatar
61
If your car is wired for ethernet, connect your ethernet to OBD cable to the car and the ethernet port to a router.
Connect your laptop to the router as well.
Switch on car and CIC and wait for a few minutes.
Then on your lapop, run this:
C:\EDIABAS\Hardware\ENET\ZGW_SEARCH.exe ( this program does not work on Windows 10 and it's flaky on a 64 bit Windows version )
Come back and tell us if you see anything in the ZGW_SEARCH screen.
thank
      12-19-2017, 02:20 PM   #22
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
I wired up the ethernet to the OBD. Hooked up a router which shows the CIC reserved an IP address. I was able to see the CIC files via FTP. Running ZGW_search shows nothing in the screen but a Refresh button.
Thanks
