07-10-2017, 04:02 PM | #1 |
3246
Rep 22,674
getBMWparts.com | Dinan DINANTRONICS Sport Tuner for G30 530i, 540i + FREE Shipping!!
getBMWparts.com | Dinan DINANTRONICS Sport Tuner for G30 530i, 540i + FREE Shipping!! DINANTRONICS Sport Maximum Gains (B58): Up to 40 HP, 50 lb-ft of torque. DINANTRONICS Sport Maximum Gains (B46/B48): Up to 25 HP, 50 lb-ft of torque. DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in a blink of an eye and yields results you will be sure to feel, and enjoy, from the get go. Coupled with Bluetooth capabilities right out of the box that allows for user controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace. DINANTRONICS Sport plugs into two sensors which lends itself to a very quick and and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment… or anywhere in between. Regardless of what setting is chosen there is a power level for everyone. Also within the app the end user has access to a live boost monitor which streams boost data in real time to the phone very similar in appearance to the sport gauges on the iDrive. Not only will you be able to feel the difference but now you can see it as well! Benefits of the DINANTRONICS Sport Performance Tuner for BMW B46/B58 & B58 Engines:
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! Last edited by Evan@Tischer; 03-22-2021 at 03:27 PM.. |
Tags |
dinan, dinantronics, dinantronics sport, getbmwparts, tischer |
