335i thinks it's in neutral
07-08-2017, 11:15 PM | #1 |
65
Rep 175
This is in regards to my 2009 335i 6AT. Today I swapped out my valve body to help fix some shifting issues. While I was at it I replaced the seals inside the transmission. Once I was done I went to start up the car to swap through the gears per the fluid filling procedure but my car won't start because it think's that it is neutral. The shifter is in the park position and won't budge since the car won't start. At first I thought maybe the shift selector on the valve body and TCM was misaligned with the selector on the transmission so I double checked it but it was installed properly. At this point I am at a loss I don't know what to check next.
Does anybody know a way to test the TCM as I fear there may be an issue with the TCM. How does the TCM interpret the gear selector position, there is a brown slider that moves with the selector but I don't understand how it can transmit any information. |
07-09-2017, 12:23 AM | #2 | |
106
Rep 808
