18x9.5 square on 09 335i sedan
07-07-2017, 01:33 PM | #1 |
39
Rep 250
Will 245 square fit? anyone running this setup?
2009 Lexus GX470
07-08-2017, 09:39 PM | #2 |
1903
Rep 6,968
07-08-2017, 11:30 PM | #3 |
39
Rep 250
07-09-2017, 05:09 PM | #4 | |
83
Rep 240
Now, the previous person to mention 265s on the rear is right, also depending on offset. I have Apex 19x9.5 with 275s on the rear and if I hit a gnarly bump I hear a rub on my bumper. I've rolled the fender and have an extra degree of camber added, but as you know the rear bumper on an E90 starts pretty high up.
PURE Stage 2 w/Inlet | Full E85 | Wedge Tuned | Alpina TCU | BMS Intake | Wagner 6" FMIC | VRSF Chargepipe | VRSF Downpipe | Boost Concepts Stage 2 LPFP | Fuel-It TBI | AEM Meth/Water | MFactory LSD | ST Coilovers | GFB DV Valve | N20 MAP
07-10-2017, 09:20 AM | #5 |
Guest
Rep n/a
Drives:
07-10-2017, 09:53 AM | #6 | |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
245s can rub since they're taller than the properly sized 255 (245/40 vs 255/35). My 255s don't even come close to rubbing up front. There's even a guy with 265s square on his LCI on here.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
07-10-2017, 06:49 PM | #7 | |
BimmerPost Supporting Vendor
1428
Rep 2,650
In some circumstances the 245 tire is stretched enough on the 9.5" wheel to clear the outer fenders without modifications, however the tolerances are tight. Tire brand, suspension type and camber settings would all need to be discussed to get you the right info. 9.5" wheels up front often times require spacers for inner strut clearance, and negative camber to prevent rubbing the outer fenders. This application makes sense for hard core track enthusiasts looking to run 265 tires up front, but pose no advantage for 245's. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
Antetokounmpo1551.50 |
07-10-2017, 08:51 PM | #8 | |
39
Rep 250
Hi Ryan, its Bobby! I would much prefer a 9" square but there was a great deal nearby on CL for 9.5" square that I was contemplating. I am going to stick with 9" with 245/40 square. Thanks for the info!
2009 Lexus GX470
ApexWheels1427.50 |
