Smoke coming from engine
07-07-2017, 01:30 PM | #1 |
Rep 13
Hi. I have an 07 335i that i bought less than a month ago. A few days later i bought it i started to smell and get a wiff of burning oil from the cabin but only when i turn off the car and i get off. The smell isnt really there when im driving only when i park the car and get out. But this morning i went to the store i see some smoke coming from under the hood. So i open it and i see some smoke coming out of the left side of the engine and some to the right. Any idea of what it could be? Its not a lot of smoke but its still noticeable and the smell is very persistent btw its an N54
Jon R
07-07-2017, 01:39 PM | #2 |
312
Rep 404
My guess would be valve cover gasket or cracked valve cover. look for oil on the heat shield just above your turbos.
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
07-07-2017, 01:43 PM | #3 |
LongDongSilver
274
Rep 706
yup or oil filter housing
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
07-07-2017, 02:04 PM | #5 |
Rep 13
First time owning a bmw. Not even a month of ownership and this happens :
Jon R
07-07-2017, 02:05 PM | #6 | |
Rep 13
Jon R
07-07-2017, 02:07 PM | #7 | |
Guest
Rep n/a
Drives:
You've got a lot to learn in a little bit of time...hope you have a couple grand set aside to get the car up to spec. |
Faredo312.00 Antetokounmpo1551.50 |
07-07-2017, 02:52 PM | #8 |
312
Rep 404
oh son.... this is just the beginning. How many miles does she have?
07-07-2017, 02:53 PM | #9 |
ahat
1036
Rep 2,592
this is the joy you have been hearing soo much about.. ;-)
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
07-07-2017, 03:01 PM | #10 |
LongDongSilver
274
Rep 706
people need to learn how to research cars before they buy them. It's way too large of an investment not to. Valve cover gasket is easy if you can wrench. If you're asking if that's a hard fix, you're in for a treat.
07-07-2017, 03:02 PM | #11 |
312
Rep 404
First time and reasonably handy? I would say 6 hours. some might flame but ive watched this happen personally.
I can do them in about 15 minutes on my own car, but I have no cowl, airbox, or anything else in the way that most n54's have. Can you do it yourself? I would say yes if you can change your own plugs, tires, oil. make sure you have a torque wrench that can reach low. like 8 inch pound low. make sure you use the correct torque pattern, and i like to used a dab of gasket sealer to seat the new gasket in place in the valve cover. they can wobble out during install. last thing. Mine once had a leak so bad it literally took a couple hundred miles to burn off the oil smell. I thought it didnt seat. So cleaning would save you some worry.
07-07-2017, 03:56 PM | #12 | |
Rep 13
Jon R
07-07-2017, 04:04 PM | #13 |
2124
Rep 2,758
Be prepared to do a bit of maintenance unless previous owners have been keeping up on it. 100k + is when a bunch of stuff is starting to need replaced
07-08-2017, 11:25 AM | #14 |
100
Rep 1,173
Hey I'm having this same issue. My car said it was low on coolant/ I saw white smoke coming from the left side and could see oil leaking down from somewhere onto the cat/o2 sensor. I took off the wheel to snap some pics yesterday.
Check my for sale and wanted threads!!! If i didn't post sold then it's still available!!
http://www.e90post.com/forums/search...&starteronly=1 Last edited by thatg; 07-08-2017 at 11:51 AM.. |
07-08-2017, 11:54 AM | #16 |
1933
Rep 1,532
Yup, it's not a difficult task but there are a lot of steps if you're not used to wrenching. Just take your time and lay the parts you disassemble out so it's easy to remember how things go back together (and take pictures for your own reference).
Chris |
07-08-2017, 09:42 PM | #17 |
185
Rep 1,017
I didn't and bought a 525 instead of a 535, now I have a n54 on a stand to put in! Live and learn.....
07-08-2017, 09:57 PM | #18 | |
185
Rep 1,017
07-10-2017, 09:27 AM | #19 | |
Guest
Rep n/a
Drives:
07-11-2017, 12:14 AM | #20 |
530
Rep 2,084
Similar symptoms here, but smoke only from passenger side of the engine. There was only oil on the heat shield. The valve cover gasket was leaking oil into the exhaust manifolds. At those miles, I'd recommend replacing the entire valve cover. They are known to crack and for the PCV ports getting clogged up.
2013 135is DCT Carbon Black Metallic |
07-11-2017, 11:37 AM | #21 | |
18
Rep 27
I can vouch for around 6-8 hours for a newbie though. I am not at all experienced at working on cars and that is what it took me. ECS tuning has a very good PDF guide detailing all of the steps. |
07-13-2017, 12:59 PM | #22 | |
100
Rep 1,173
I found it sorry i dont internet good http://bd8ba3c866c8cbc330ab-7b26c6f3...eplacement.pdf
http://www.e90post.com/forums/search...&starteronly=1 |
