MMP Stage 3 Turbos Install
07-03-2017, 10:50 AM | #1 |
101
Rep 229
Drives: 08 E90 335i 6 spd MT
Hello, my dudes.
I installed my MMP Stage 3 turbos this past weekend. This was a breeze as I have done plenty N54 turbo installs... I've lost count. I am also going to be installing: Twisted Tuning's port meth injection plate. 6x375 ml/min nozzles and a 7th d03 nozzle at CP AEM controller v2. Fails safe flow sensor. (AEM) Wot Box 2 step. NLS. Current Setup: · Index 12 Injectors / New HPFP · NGK 95770 1 step cooler. Gapped to .022 · New Coils- OEM Bosch · 7th Meth Nozzle D03 – after Intercooler. Bolt Ons: · 3.5 Bar n20 TMap. · 7" FMIC HD VRSF · SYNAPSE BOV - CHARGE PIPE · BMW DOWNPIPES CATLESS · CATLESS EXHAUST - PE MODED · Hot Side Inlets 2.5” – PCV Vented to Atmosphere · MMP Outlets 2” Wheels: 17" Koosei K1's with Hossier DR Will Tuned by Ken Atkinson himself. Dyno Coming Soon. NOTE: removing the radiator support is not necessary when installing turbos - there are other reasons why I decided to remove the radiator support. |
07-05-2017, 12:09 PM | #2 |
101
Rep 229
she's done.
07-05-2017, 12:16 PM | #3 |
202
Rep 749
Drives: 335i xDrive
Very cool
Thanks for documentation that car was rwd right? |
07-05-2017, 02:27 PM | #4 |
101
Rep 229
07-05-2017, 03:22 PM | #5 |
LongDongSilver
274
Rep 706
what's your suspension setup? are you still open diff? couple guys around here making 600 whp on those turbos, with just meth and 91, so I'm curious what these will do with port injection thrown in
N54 E90 6AT: 3" Pipes that go down, Thing that cools the inter, PE Mod, DCI, ST XTA, Whiteline bushings, Aodhan, and lotsa corn-juice
07-05-2017, 04:15 PM | #6 | |
129
Rep 712
They explain power levels on the right in the description using Stage 3 LPFP and PI. |
07-06-2017, 12:13 AM | #7 |
101
Rep 229
^^^ see the link. above
at the moment the biggest restriction with these turbos is the exhaust manifold. 30psi is about as much as you can get out of these turbos the way they are now due to back pressure....... can't wait for the upgraded manifold. |
07-06-2017, 01:30 AM | #8 |
347
Rep 2,281
Don't mean to thread jack, but.
I could not find anything on removing/ replacing the radiator support. Would you mind getting into that a little. Mine is cracked and it looks like a bitch to do. Thank you. |
07-06-2017, 10:22 AM | #9 |
1027
Rep 1,264
Nice work! Look forward to seeing dyno results.
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135 📷 Follow me on Instagram: instagram.com/jakespence 🏁 Shop BMW merchandise: bimmerstreet.com |
07-06-2017, 12:32 PM | #10 | |
101
Rep 229
Super easy. no need to remove the fan or the radiation. Remove bumper-- undo fasteners by the kidney gril-- 2 fasteners on the side through the wheel wells. remove.. make sure your under cover is off as well. remove bumper. unplug fog lights or park sensor. now you remove the head lights. 2 fasteners holding the headlight light bracket to the chassis. and one hastener holding the headlight brack you can see it by removing the wheel well plastic covers. remove the hood latches then you want to unbolt the impct bar.. unplug you horns - 4 bolts on each side .. and pull that off... then you can simply unbolt the radiator support from the car. 2 bolts on each side by each fender.. and remove. i wish i had pics for you but i dont have time to go through them and circle the steps.. its super simple. just get in there and get it done. |
07-06-2017, 07:10 PM | #11 | |
347
Rep 2,281
OTN5538.50 |
07-06-2017, 08:56 PM | #12 |
101
Rep 229
07-06-2017, 08:57 PM | #13 |
101
Rep 229
ready to start the meth setup
07-07-2017, 08:58 PM | #14 |
101
Rep 229
installed
07-09-2017, 07:40 AM | #19 |
101
Rep 229
Becuase hot temps are upon us. i do not recommend the vr1 stuff for anything other than strictly summer.
Normally I use motul o100x 5W 40. |
07-10-2017, 06:35 AM | #21 |
180
Rep 772
Drives: 2015 435i grand coupe xdrive
Can I ask how you vented you PCV to atmosphere? I'd like to do that rather than run a catch can myself.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
07-12-2017, 02:01 PM | #22 |
234
Rep 317
It's pretty straightforward. There's no PCV connection on relocated inlets, and it comes with a ginormous hose that you connect to the PCV vent and run down the driver's side of the engine bay.
arhoads335i179.50 |
