Steering wheel shaking
07-03-2017, 02:06 AM | #1 |
40
Rep 345
Hey guys! Hope all is well. I've been trying to figure this issue out for awhile on my 2011 328i. Car has 100000km and is in excellent condition.
I get a pulse in my steering wheel at random speeds and sometimes it pulses even worse during braking. The tires have been balanced and rechecked and they are perfect (70% tread left) The wear is even front to back Brakes and rotors were just completed 4000km ago with OE tekstar and zimmerman parts I have a 2009 car as well and it drives soo smooth. I wish this would drive the same way. I just had it checked out for suspension wear and nobody could find anything out of the ordinary. All advice appreciated |
07-03-2017, 02:56 AM | #2 | |
Touring cars rock
351
Rep 907
Sportwagon Daily: I've done some stuff.
07-03-2017, 08:28 AM | #4 |
40
Rep 345
Makes sense.. strange thing is I have two E90s and my other one just had these bushings replaced.
Prior to the repair it never really shook the steering wheel at all. Oh well.. thank you guys! |
07-03-2017, 02:34 PM | #6 |
38
Rep 111
If you can DIY, it makes a lot more sense just to replace the whole arm rather than dealing with trying to press in the bushing. A set of M3 arms with solid bushings are around $175 from Turner Motorsports and they're a direct replacement. A set of bushings is about $80 so it's easier just to replace the arm and get better steering feel at the same time.
However, you can also get steering wheel shake when installing new wheels that have a center bore diameter that's larger than the brake hub diameter. You need hub-centric rings to fill in the space and that will fix the steering. |
Fb201740.00 |
07-04-2017, 08:26 AM | #7 |
40
Rep 345
Any idea if the M3 arms will fit an xi car? Not sure if there are any major differences in terms of fitment.
I would love to put the more robust m3 bushings but I may end up having to go back to OE sadly. If anyone here has done the thrust arm bushings my only question is how did you go about putting the suspension back under tension prior to tightening. Doesn't seem to be much room with the car down. If I drop the car on a set of ramps, do you think that would be acceptable? Or would there be too much/little compression in that case? As for the wheels I'm running powder coated OEM so no rings required |
07-04-2017, 11:19 AM | #8 | |
38
Rep 111
Fb201740.00 |
07-04-2017, 05:12 PM | #9 |
40
Rep 345
This is going to be pretty stupid but thrust arms are they the same as upper control arms or as bmw calls it traction strut? I had the bushings changed at a garage for the other car but plan to take this on myself.
Any part numbers would help. I tried to google but can't find anything to clarify what parts I need Thank you in advance! Front thrust arms for 2011 328xi |
07-05-2017, 01:53 AM | #10 | |
38
Rep 111
96146-08025970 96146-08025971 |
07-06-2017, 12:23 AM | #11 |
Touring cars rock
351
Rep 907
Dont replace the arm, replace the bushing with poly. The fluid filled OE ones are a disaster.
07-06-2017, 02:57 AM | #12 |
38
Rep 111
Unless he has access to a hydraulic press he won't be able to get the bushings in or out and shops charge a fortune to do it, at least where I live. The local shops charge $200 extra just to press them in. My bushings are just now wearing out at 127k miles. The OEM ones will be fine for his purposes
07-06-2017, 05:12 PM | #13 | |
Touring cars rock
351
Rep 907
Better, I went to Harbor Freight and bought a $60 press and it works just fine. The OE ones fail at totally random intervals. I have seen new arms with only a few thousand miles rupture from a good pothole hit. If he's paying to have them pressed in/out the price of the bushings and labor would be less than the cost of the new arms. Don't replace what isn't broken. The failure mode for this assembly is the bushing. There is almost universal acceptance that the high durometer poly option is the way forward here. It's an improvement over the OE is EVERY way imaginable. Not to mention there is no difference in NVH and the car handles light years better without that arm moving all over hell in the corners.
07-06-2017, 06:10 PM | #14 | |
38
Rep 111
07-06-2017, 06:54 PM | #15 |
Touring cars rock
351
Rep 907
In fact, most shops have a press they can use on the car when the car is on the lift. They are not hydraulic, but a good shop will put the car up in the evening day before, spray down the bushing with liquid wrench, and then press them out in the am first thing.
On a lift this whole job can be done in less than 1 hour. Even pulling the whole arm and using the hydraulic press, you can do this entire job in 45 minutes on a lift if you've done it before. All you need is a ball joint puller and it's under 5 minutes round trip, save for the time on the press. I would NEVER advise replacing the whole arm on these cars, as the weak point is the bushing. Why replace a blown up part with another part that's prone to blowing up? That's just insanity. REMEMBER TO RE-TORQUE THE THRUST ARM AT RIDE HEIGHT!!!
miker201365.00 |
07-08-2017, 12:37 PM | #16 |
40
Rep 345
Hahaha thanks guys. I would love to do the pressing option but there aren't as many shops available that don't charge an arm or a leg. For the rest of the cars life its going to be mostly highway driven so hopefully OE control arm replacement will be sufficient.
+ this way I can do the work myself rather than paying someone else to do it for me If anyone has suggestions of what they used to raise the suspension with the wheel off please feel free to share Thank you everyone |
07-08-2017, 01:04 PM | #17 | |
181
Rep 657
07-08-2017, 02:05 PM | #18 |
Touring cars rock
351
Rep 907
07-08-2017, 09:55 PM | #19 |
40
Rep 345
Just to make sure I've ticked all the boxes before throwing more money at the car I noticed that there is no oil or fluid around the bushings as most people notice when the bushing is toast.
Can a bushing perish without leaking? Any idea if it washes away pretty easily? Also there is little to no play in the wheel when wobbling it (1 wheel jacked at a time) Common sense would say that it feels normal but I really don't know anymore. Would the tiny questionable residue in this picture be the oil? |
