Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacers or new rims and tires?
      07-01-2017, 08:10 PM   #1
KK4MEI
25
Drives: 2005 BMW X3
2009 335i sadan w/ M sport package.
Should I just add spacers 20 back 15 front or get new wider rims and tires?
Anyone know of a good wide rim and tire combo for this car?
      07-07-2017, 07:02 AM   #2
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
Wider wheels
Anything apex makes, they're very light, durable and relatively affordable.
Also 20 is much too big for the rear of an lci.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      07-07-2017, 11:02 AM   #3
Faredo
Faredo's Avatar
312
Drives: 335i
I run 15 front 20 rear but its a coupe. there was very slight rubbing on the inner fender liner that went away in a couple miles.
If you're wanting to stay away from spacers, I would recommend getting the entire wheel instead of just the rim. Its a pretty custom job to change the rims on your wheels.
Below is 15/20 spacers
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
      07-07-2017, 11:45 AM   #4
PR3CI5N
need4speed
PR3CI5N's Avatar
510
Drives: 2010 E90 M 335i
On my 2010 E90 M 335i, I had the 18" hyper silver Apex Arc-8's and I loved them. The car handled better and felt much more nimble. From the stock 193M wheels, I shed about 7lbs per wheel by switching to Apex and I could really feel the difference.
Front: 18x8.5 et38 (I'd suggest the 18x9 et42)
Rear: 18x9.5 et35
N54
      07-07-2017, 12:50 PM   #5
Antetokounmpo
1552
He certainly means getting new wheels, not just rims people use rim and wheel interchangeably. plus you cannot change the rim on a 1 piece wheel. The rim is really called the barrel too.
coupe fitment is about 8mm narrower than lci sedan.
      07-10-2017, 03:16 PM   #6
Underground6t9
Underground6t9's Avatar
317
Drives: BMW 335xi, Lexus is250
It all depends on original wheel offset. do some measuring to find out how much room you have.
|instagram@underground6t9|
      07-12-2017, 05:35 AM   #7
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
What is your current set up?
M- sport..
18" rims
225 width in the front & 255 in the rear ?
They say to go conservative 12mm front & 15mm in the rear. There is a way of measuring, in order to determine which width of spacers are appropriate per axel. You should look up the diy for this.
